Old 11-15-2002, 12:00 AM
Red_Liner740TIC Red_Liner740TIC is offline
b16a turbo, fuel delivery q's
Aight, i'm new here and not too much into Hondas but me and my friend are seriously thinking of turboing his CRX with b16a.
we're going with a Mitsu TDO5-13c from my Volvo (center cartridge is shot, but we're gonna get a new cartridge)
we got all the turbo stuff figured out...
the manifold, the oil and coolant lines, the intercooler, BOV, the piping etc...
what i dont know about the b16a is the fuel system and how much boost it can support stock.
what would i need to upgrade so i dont granade the engine? fuel pressure regulator changed to a RRFPR? what about the Fuel Management Unit? does it have it, will it need it if it doesnt have it
(my Volvo has the AMM to measure air and to deliver enough fuel, how does Honda do it, since i didnt see any AMM on it).
also what numbers to expect from this setup runnng about 5, 6 psi.
thx guys...
Old 11-15-2002, 02:43 AM
91civicDXdude's Avatar
Fuel Management Unit (FMU)= RRFPR. its the same thing. 5-6 psi i've heard is safe on stock internals without much ignition/fuel upgrades. A good investment is either factory replacement, or additional fuel pump. Walbro makes a good inline pump. with the fuel pump and FMU you should be okay and not detonate, but to be sure, you might want to pick up some that will retard the timing at high rpm to accomodate for the boost.
Im curious as to the hp numbers as well becasue im about to start building a junkyard turbo for my single cam running about the same setup. IM JUST GUESSING, but 5-6psi on a turbo should be 40-60hp but i could be way wrong.
good luck.
Old 11-15-2002, 04:26 AM
H4Bangin's Avatar
H4Bangin H4Bangin is offline
Send a message via AIM to H4Bangin
i know a guy with a 90 hatch with a B16 turbo he ran 12.8 at sacramento track, i guess its somewere on the net its white with a -www.modacar.com sticker in the back window
********** My 94 SS **********
90 civic dx 4 door d16z6 - p28, aem intake, act stage one clutch, cheap header- commuter car
Old 11-15-2002, 03:45 PM
So Hondas control the fuel pressure through the Fuel Management Unit?
oh, and do b16a's come with knock sensors?
cuz if they do i can use the Saab's APC unit to detect detonation and and cut back on boost...
as for retarding the timing, what would i need? my car comes with that already and the computer adjusts it...
how much money are we talking for the fuel system upgrade necessary for the turbo?
Old 11-16-2002, 04:47 AM
TrailerParkJake TrailerParkJake is offline
Send a message via Yahoo to TrailerParkJake
you can also do an afc hack....get an vafc, and dsm 450 injectors, and reduce the injectors flows through the afc. to control the timing, you can use a msd 6al(i think...sorta drunk right now it could be something else...) the dsm injectors should mount up fine with minimal modifications. Also, you wont have to deal with check valves that you normall would with an fmu. ill post some links when im somewhat coherentt
When I started reading about the evils of alcohol, I quit reading .
Old 11-17-2002, 03:44 PM
Fishcat37's Avatar
Fishcat37 Fishcat37 is offline
Send a message via AIM to Fishcat37
Yes, the B16A uses a knock sensor. It is located on the back of the block...about in the center of the block, and very close to where the block mates to the head (right below the IM)
FLINT BLACK 1990 CRX SI
Appearance Mods:
-JDM EF8 CR-X SiR Spoiler
-94/95 Integra GS-R rims
Performance Mods:
-JDM B18C swap
-OBD1 conversion
-Chipped P28 ECU
-Skunk2 Intake Manifold
-DC Sports 4-2-1 Header
-MSD SCI-L ignition
-EXEDY Racing Clutch
Interior Mod
-'95 Integra GS-R Gauge Cluster
Former Motors - RIP:
-JDM B16A #1- Blew up due to over-revving
-JDM B16A #2 - Hydrolocked
Former Cars
'89 CRX Si - "The Bumblebee"
'94 Integra GS-R
'96 Camaro
Old 11-17-2002, 11:37 PM
so it does have a knock sensor?
excellent...the Saab's APC will go on the car as well...
great.
Old 11-18-2002, 01:24 AM
SkyNex721's Avatar
SkyNex721 SkyNex721 is offline
Send a message via AIM to SkyNex721
http://www.homemadeturbo.com/b162.html
Check it out. It's got all the details of making and installing a home made turbo onto a b16a powered CRX.
R.I.P. - You shall be resurrected.
B16A all motor or B16A Turbo Lou09 JDM Motor & Parts info/chat 7 12-20-2007 02:53 PM
Fuel Delivery Problems Nitro Junkie Grand Marquis 0 11-30-2003 02:14 PM
525 Diesel Fuel Delivery Pump Drawing Air 525diesel 5 Series 1 11-09-2003 04:06 AM
86 300ZX fuel delivery problem costa510 240Z | 260Z| 280Z | 300ZX (Past Z Cars) 1 11-07-2003 08:51 PM
fuel delivery system rerun Mustang Talk 4 09-04-2003 07:24 PM
