Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 01-18-2002, 10:34 AM
Inspire95 Inspire95 is offline
Send a message via ICQ to Inspire95
B16a Turbo--> Cost Efficiency?? help
Im wondering how good a B16a if its turbocharged?
What are the things needed to be done to the internals of the engine to accomodate 12psi of boost from a turbo?
What are the drawbacks? like lag and all ..and how do u avoid it?
Any special way of maintaining such engine?
How fast do this things go?
Thanks guys! Im just a curious joe here..hehe! hope you can help!
God Bless!
Old 01-18-2002, 05:24 PM
TrUnKs714 TrUnKs714 is offline
Re: B16a Turbo--> Cost Efficiency?? help
God Bless!
u prolly need to get the engine resleeved new lower compression pistons. the only lag is turbo lag, bigger the turbo, mad power but also mad lag. maintain it by not boosting it at 12 lbs all the time. remember to get a turbo timer for the spindown.
Old 01-18-2002, 11:49 PM
Thanks man!
what is resleeving by the way? im new at this.
What about pistons and con rods? what do u need them 4?
Whats a turbo timer 4? how does it work 4 u?
thanks again!
God bless!
Old 01-20-2002, 09:44 PM
pvang31019 pvang31019 is offline
search
Old 01-24-2002, 11:22 AM
MatT3T4 MatT3T4 is offline
Send a message via AIM to MatT3T4
You don't need to resleeve your motor, you don't even have to open it up.
In order to be safe, with 12psi on a B16A, you will need the following:
- ample fuel: 370cc injectors, in tank hi-flow fuel pump, adjustable fuel pressure regulator
- spark: I prefer MSD...box, wires, plugs, etc...
- tuning: A'pex V-AFC, Hondata, DFI, etc...
So long as you have ample fuel and spark, and the motor is well tuned, you will be fine. B-series Honda motors are extremely strong. They can withstand 350hp...but only if they are well tuned. Tuning is key. On a daily driven turbocharged B-series Honda motor, you should really never have to mess with a built motor unless you plan on spinning your wheels, and getting smoked by Geo Metro's because you have no traction...
Old 01-24-2002, 01:33 PM
what do u mean by "you should really never have to mess with a built motor unless you plan on spinning your wheels"?
By the way...what have you heard about HKS ball bearing t25s? How are they...I was thinking of going for as low as 8psi so I can preserve more engine life and those f-con piggys sounds nice too.
Whatcha guys think about this? What about injectors..what type are ideal for this kind of turbo?
Thanks guys!!
Old 01-24-2002, 01:39 PM
Thanks guys!!
By saying that, I mean that the stock motor can handle up to 350hp. On the street, 350hp is so much that you will already have NO traction. Anything more, and you will be even worse off for the most part...
Turbo Guru v1.0
http://www.MatT3T4.20m.com
Old 01-25-2002, 07:38 AM
Spunkymonkey's Avatar
Spunkymonkey Spunkymonkey is offline
God Bless!
There is a civic with a turbo B16a here, which apparently runs mid 11's for a quarter mile.
There's a chick driving that thing
www.performanceforums.com
Old 01-25-2002, 09:19 AM
I used to have a B16A with a custom Rev Hrd turbo kit in my EJ. B16A turbos are SICK! My car ran 12s on street tires. I never clocked it on real slicks, but it was an 11 second car. That was with the stock internals. After I built it, it didn't change, I never really boosted extremely high, but you get the idea...it was extremely fast, and was my one and only daily driver.
Turbo Guru v1.0
Old 01-28-2002, 05:54 AM
TypeSi TypeSi is offline
so would a t3/t4 turbo be too big? will it have mad lag or what will be the ideal turbo for the b16
often imitated but never duplicated
Old 01-28-2002, 09:04 AM
T3/T4 works great...
Turbo Guru v1.0
Old 01-28-2002, 02:40 PM
depends what trim though...
Old 01-28-2002, 03:04 PM
well for my trim a 00 si with just the turbo kit would that be cool, boosting no more that 6-8 psi. (drag 3 kit)
Old 01-28-2002, 11:44 PM
what trim turbo?
Old 01-30-2002, 01:43 AM
what trim turbo?
the t3/t4 trim mainly the grag 3 kit
B16A all motor or B16A Turbo Lou09 JDM Motor & Parts info/chat 7 12-20-2007 02:53 PM
Turbo and turbo parts cost Carfreak18 Cavalier 1 12-21-2004 05:09 PM
Easy Cost Efficient Upgrades? FastGuy000 Celica 7 03-30-2004 03:36 PM
993 TT Cost efficient ?? DemoX 911 0 08-12-2003 10:17 AM
