Old 05-07-2004, 03:41 AM
7th_skyline's Avatar
7th_skyline 7th_skyline is offline
Building a Fujimi MK1 GT40, some Q's
Ok, first up, do any of the Fujimi mk1 GT40 kits have engine detail? I'm not too worried if they don't I'd just like to know.
Secondly, is it a good kit??
Thirdly, I will probably be doing the Kojima/Yamaha car (GT40P-1077), Alan Mann test car or the cartograf decal MK1 street kit, which wheels do you get? BRM or Halibrand? I would ideally like some BRM's. Also, are there any significant differences in these 3 kits beyond decals and moulding colour?
I am planning on basing my model loosely on an acquaintances real GT40 MK1 Replica which is currently in the build here in Australia and will be frighteningly quick - ie alloy block 364 ford windsor based stroker small block, air flow research heads, 8 throttle injection, motec, engine built in the 'states, hooked up to an audi motorsport transaxle - It made 500hp on the engine dyno at 6300rpm (it can rev significantly higher, this motor is the best of the best...) with a holley carb and dyno headers!! It will make a lot more power with the motec computer, 8 throttles and specific tuned exhaust...
Externally it is red with white striping, and rolling on BRM's. It has Gurney/weslake rocker covers for the period look Though I dare say there weren't too many alloy block, stroker windsor based GT40's in the 60's
as a side note, the same nutcase also has a road legal MY99 WRX which is being developed for circuit sprints (too heavily modded for any organised class based racing or tarmac rallying), which is currently making in the region of 400hp at the tyres (on an awd dyno) on 16psi of boost, but it is built to run 30psi when run-in...8 piston AP brakes which barely fit under 18" rims, 6 speed box, full roll cage, and more stuff than I can fit here..... Oh and an R33 GT-R that is currently disappointingly stock, except suspension and Buddy club bronze/polish 18" P1's...
some people....
Current projects:
-Tamiya KPGC10 Skyline into L28 powered "street racer"
-Aoshima "Puchiage Racing" Celica XX
-Aoshima "ChikiChiki Racing" C110 GT-X Skyline
-Widebody DR30 RS-X
-Tamiya F40
-Widebody HR31 GTS-R with Lamborghini OZ 345s
Old 05-07-2004, 05:15 AM
935k3's Avatar
935k3 935k3 is offline
All of Fujimi's Ford GT's are curbside(no engine)but there is a resin kit available in the US of the entire engine,transaxle and rear suspension. The kit is very high quality resin casting.
Old 05-07-2004, 07:38 AM
tonioseven's Avatar
Re: Building a Fujimi MK1 GT40, some Q's
I have the Kojima version; It's excellent!! Currently contemplating doing the engine conversion for it though.
Old 05-07-2004, 08:15 AM
RallyRaider's Avatar
Zomby Woof
Judging by the box art the Kojima kit has six spoke BRM wheels, can you confirm that Tonio?
Interesting tidbit if information - the rear Halibrand wheels in Fujimi’s 1966 LM winning Mk II kit (and possibly others) are not symmetrical! The lip is slightly different on either wheel, not hugely noticeable, especially when they are fitted to opposite sides of the car. Weird though
Old 05-07-2004, 08:51 AM
tonioseven's Avatar
3 Pictures...
You are correct Phil! Here's 2 quick pictures...
Also: there are several extra parts in the kit for building different variants I suppose. See the shaded areas in the pic below
Old 05-07-2004, 09:18 AM
Samurai75007 Samurai75007 is offline
wow dang I might hafto get two of this kit...
Old 05-07-2004, 09:36 AM
Vric's Avatar
Vric Vric is offline
the one you have don't have photoetched part ?
most of the fujimi GT40 go have PE sheet
Old 05-07-2004, 11:41 AM
tonioseven's Avatar
No, not all of them do.
Old 05-07-2004, 02:47 PM
drunken monkey's Avatar
Razor Sharp Twit
seeing as we're on the question of gt40s...
do any of the kits available past or present have a ful engine or do i have to source one of those?
AF's Guidelines
Read them.
Old 05-07-2004, 02:54 PM
tonioseven's Avatar
You'll need to source one I believe.
Old 05-07-2004, 09:22 PM
Zomby Woof
Yeah none of the Fujimi GT40s have full engine detail. Only the part of the transmission that is visible from the rear. Of the kits I have, only the Mk II has PE included. Studio 27 make a nice set for the Mk I.
Old 05-07-2004, 09:26 PM
Zomby Woof
Hang on I do remember seeing an old GT40 kit that had a full engine. Can't remember the manufacturers name, Japanese I think. Was about to snap it up until I noticed it was in 1/25th scale
Old 05-08-2004, 11:18 AM
Kurzheck's Avatar
Kurzheck Kurzheck is offline
AF Premium User
Harold Bradford makes a resin conversion to put an engine in the MK.I GT40. Check ou the link...
http://gallery.bcentral.com/Gallery/...28&Dept=365063
Corner 5 Hobbies
Guelph Plastic Modellers Group
www.thesprue.com
Old 05-08-2004, 11:38 AM
levincer's Avatar
levincer levincer is offline
Send a message via Yahoo to levincer
It's a good kit
Hi,
Just have a look on the last thread in my signature and u'll have some pictures of the GT40.
