Old 04-15-2004, 01:11 PM
Sticks21 Sticks21 is offline
Question SES code 440...
Have a 97 Grand Prix GT with 102,000 miles. My service engine soon light came on...took car to Auto Zone and it showed code of 440 which is an Evap emission control system malfunction. Possible causes were bad gas cap (replaced), vacumm leak at engine (couldn't find one), the EVAP cannister, hose cracked or a defective purge or vent solenoid. Don't have a clue about where they are or how you check them....anyone out there know?? or is it time to take it to a professional??
Old 04-18-2004, 11:44 AM
kilroypr's Avatar
kilroypr kilroypr is offline
Send a message via MSN to kilroypr Send a message via Yahoo to kilroypr
Re: Help...SES Light is on
I do not remember seen the evap canister on my GTP. I know that ripn12s or CarnutCass can tell you where it is located. PM them on that
Old 04-18-2004, 12:12 PM
e2helper e2helper is offline
Cannister Purge solenoid: Top front of the engine, on the intake manifold near the fuel injectors
Cannister Vent and solenoid: Behind the left side of the rear fascia splash shield, behind the wheel well. You have to remove wheel and wheel house liner.
Here is a link to service information on this code if you want to read thru it. Hope this is a 3.8L engine - I wasn't sure
http://www.geocities.com/raj380/mali...iagnostics.pdf
Pretty complicated stuff since it takes 8 pages (LOL)
Old 04-18-2004, 12:22 PM
kilroypr's Avatar
Well now we have 3 sources, e2helper , ripn12s and carnutcass
Old 04-18-2004, 06:43 PM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
Other things that could cause this code are
Fuel tank pressure sensor
Air leak at the sender
vaccum lines off anywhere on the fuel vapor lines
Shop Foreman Buick Pontiac and GMC dealership
ASE Master Tech
ASE Advanced L1
GM Master tech
Licensed Aviation mechanic
Old 04-18-2004, 11:49 PM
kilroypr's Avatar
Flatrater, aren't those leaks supposed to give you a fuel smell around the engine bay?
If that is correct, Sticks have you felt such as smell on your car?
Old 04-19-2004, 12:38 PM
Thanks for the help......don't smell gas anywhere....at least now I know where to begin to look....will let you know how things turn out..
Old 01-15-2005, 10:36 PM
bennerh bennerh is offline
Re: SES code 440...
i have the same message with code P0449. i just bought a purge solenoid canister vent valve blah blah...I havnt installed it yet but it only cost $25. and should take only 5 min. to install.
If you cant find the canister...buy it, remove the engine shield, you cant miss it. If it was a snake...
PLEASE HELP !!! Security light stays on after car starts Alero_H8er Alero 4 10-28-2010 08:53 AM
Check Engine Light or SES Light HELP!!!!! frankie1320 GTI 3 01-03-2005 09:02 PM
I need help SES light!! transam99 Camaro Discussions 6 09-14-2004 01:05 PM
Help me... Please... WAY WAY low gas millage... and no SES light!!! htoudiee Sentra | 200SX (USDM FWD) 2 03-01-2004 10:57 PM
SES light help CamaroZBoy Sentra | 200SX (USDM FWD) 2 01-31-2004 11:14 AM
