Old 08-06-2004, 12:06 PM
transam99 transam99 is offline
I need help SES light!!
I have a 99 T/A A4 with a few bolt ons, predator prog, 3.73 gears. My problem is an SES light that comes on at idle. It starts idling real rough and almost dies, it throws two codes every time i stop for 15 secs or more, p0270 (fuel trim bank2 too lean), and p0300(random multi cyl. misfire) Has anyone had this problem?
Old 09-05-2004, 07:15 PM
95fbodyunder3k 95fbodyunder3k is offline
Re: I need help SES light!!
what are yer bolt ons some of those might be the problem
Old 09-06-2004, 11:49 PM
DarkblueTA's Avatar
DarkblueTA DarkblueTA is offline
Send a message via AIM to DarkblueTA
What cylinder is mis-firing? that should tell you. Have you swapped plugs/wires lately?
The lean code...does it say bank 2 sensor 1(or 2)?
You might not have a plug wire put on all the way, or left one off. I did that one and got an SES light with misfires right aways. As far as the lean..not sure. Maybe a bad sensor...swap it out with the other sensor on that side
DarkblueTA
GT70, FMIC, Alky-water injection, Hooker Cat back, 208/230 .549/.579 121LSA Cam, forged diamond pistons/eagle rods, LS6 block, Lakewood LCAs, BMR STB/PHRB/Sway Bars, poly torque arm bushing, Spec Stage 4i clutch, B&M Ripper Shifter, SLP Subframes, 60# injectors, KYB AGX shocks/struts, Moser 12 bolt(373 gears, 33 spline axles, posi, ta girdle/etc/etc/etc) and HPTuner kit
2007 Nissan Titan Daily Driver. 2* advance
Old 09-07-2004, 01:13 PM
TransAm_Ownr TransAm_Ownr is offline
Send a message via AIM to TransAm_Ownr Send a message via MSN to TransAm_Ownr Send a message via Yahoo to TransAm_Ownr
Hey man ive had this problem before...Check the wires are they touching? if they are there is your problem because mine was fixed after i untouched the wires. Tell me if it works.
Old 09-13-2004, 08:06 PM
99onI95's Avatar
99onI95 99onI95 is offline
As for the lean problem that could have something to do with Mass air flow sensor. Have you unhooked it? More HP but leans out the motor. As for the idle plug wires are a great start but also check your fuel filter I know a GM guy who swears that a clogged filter causes more problems than anything else.
Old 09-13-2004, 09:38 PM
[quote=99onI95]As for the lean problem that could have something to do with Mass air flow sensor. Have you unhooked it? More HP but leans out the motor.QUOTE]
so if the engine gets to lean it will wanna quit running right???
Old 09-14-2004, 01:05 PM
3000GT_Formula_350 3000GT_Formula_350 is offline
Banned
ya it will want to start breaking things such as rods and pistions.
