Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 04-15-2004, 08:34 AM
d-d-2k d-d-2k is offline
Question My Fog lights are staying on
Hi, I have a 2000 Dodge Dakota and was woundering if any one has ran into this issue before. My fog lights are staying on when I turn off the truck and the switch. Ive pulled the relay and they are still on. I also see the light on the switch staying on telling me my fog lights are still on when the switch is off.
Old 04-23-2004, 09:00 AM
dakotafixer dakotafixer is offline
Re: My Fog lights are staying on
Does the headlight switch also control the fog lights? I know it does in the 99. If so, you will probably have to replace the headlight switch in the cab and it should take care of the problem.
Old 05-19-2004, 09:13 PM
jaredja16 jaredja16 is offline
Send a message via AIM to jaredja16
check your wiring and make sure that you don't have a bare wire in contact with the frame, this will cause a short and fog lights will stay on. Did you install the foglights or are they stock?
When I help my friend install aftermarket fog lights on his 98 Dakota, we had a similar problem, the foglights would turn on even if the the truck was turned off. We fixed this by keep the braket from grounding to the frame.
Old 05-19-2004, 11:28 PM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
When my daytime running lights were stuck on, I had to unplug this connector that was located on the inner driver-side fender. It's about the only plug connector mounted on the inner fender itself. This is on my Ram, not a Dakota, but it is a start of advice for you anyway. Good luck.
94 Mercury Villager oil pressure light flickers; stays on runnergirl262 Villager 1 04-15-2010 08:46 PM
Fog lights not working misguru Cherokee 1 12-31-2009 12:55 PM
How to get Fog Lights to stay on with High Beams??? 383stroker_1 Grand Prix 19 11-20-2005 11:32 AM
1999 taurus interior lights are staying on. help! busa4 Taurus | Taurus Wagon 9 04-01-2005 07:31 PM
Expedition--interior lights are staying on. katmat Expedition 7 01-19-2005 08:00 PM
