Go Back   Automotive Forums Car Chat > Ford > Expedition
Old 01-17-2005, 06:51 PM
katmat katmat is offline
Expedition--interior lights are staying on.
The interior lights are staying on in my 2003 Expedition. I have checked every switch and every door and cannot find the culprit. Any ideas?
Old 01-17-2005, 08:42 PM
expedition-2003 expedition-2003 is offline
Mine does that if it thinks a door is ajar. If I hit the remote lock twice and the horn goes off twice then it thinks a door is ajar. If the horn goes off once all is good.
Old 01-17-2005, 09:45 PM
al52269 al52269 is offline
Re: Expedition--interior lights are staying on.
Hello!
Hope your well...
I had the same problem with the door ajar light. after taking everything apart and no luck. A old timer mechanic told me to spray WD-40 on the door jams and locking device guess what it work. hope this helps. Sincerely, Al
Old 01-18-2005, 07:52 AM
bearcat329 bearcat329 is offline
Talking
had the same problem, sprayed the door lock assy's with wd-40, all works fine now, make sure you give all the latch assemblies a good shot
including the rear hatch/door as well.
hth
Rick, Ore
Old 01-18-2005, 04:20 PM
fry628's Avatar
fry628 fry628 is offline
After spraying with WD40 follow with SPRAY silicone lubricate or the oil in the WD40 will attract dust and you'll have the same problem.
Certified Ford tech for 10 years
Old 01-19-2005, 07:27 PM
yotermanic yotermanic is offline
I've had bad headlamp switches cause this problem before. Is the door ajar light on on the dash?
Old 01-19-2005, 07:56 PM
Yes, it is but it is not showing, plus I checked every door including the hatch and none were ajar.
Old 01-19-2005, 08:00 PM
This is interesting because my "clicker" has never worked consistently. I have never known if the problem was the remote lock or the receiver on the SUV. Very often we have to hit it repeatedly to get it to actually lock.
