Old 03-27-2005, 09:11 AM
busa4 busa4 is offline
1999 taurus interior lights are staying on. help!
my interior lights are staying on. both my dome lights are staying on when key is out of ignition. i arm the alarm system and the lights never shut off. it has already burned out the front interior lights and started melting the rear dome light cover. i replaced the gem module and there was no change. every day i have to pull fuse 23 (gem, pats, rap module) to save my battery. if i remove/unplug all the lights that are staying on i still have a 0.400 amp drain on the battery which is draining the battery overnight. what are some things that keep the dome lights on? thanks for all the suggestions you can give me.
Old 03-27-2005, 12:42 PM
Banjoman10 Banjoman10 is offline
Re: 1999 taurus interior lights are staying on. help!
Are you sure your dimmer switch is off? At the max brightness if you push further, it will click, and those lights you describe will come on and stay on, no matter what. This happened to my daughter, she called me from hundreds of miles away, in panic, that they couldn't make the interior lights turn off. I suggested the dimmer switch. It worked, that was the culprit. Also, that switch could be faulty as well.
Old 03-27-2005, 01:02 PM
great thanks. i will check that out now and let u know.
Old 03-28-2005, 08:15 PM
that was the problem. i guess i forgot the first rule in auto mechnics. k.i.s.s. (keep it simple stupid)
1 more question. the current drain dropped down to 0.230amps. according to everything i have been trained on that is very high still. i left it there for about 15 minutes and it still didnt drop below that amperage. is it possible if u can compare your drain to mine?
thanks
joe
Old 03-28-2005, 10:01 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Re: 1999 taurus interior lights are staying on. help!
Did you by chance have the hood open with a hood light on when you measured that, or a door open? Or maybe the glovebox was open?
-Rod
thanks
joe
Old 03-29-2005, 06:42 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
I am almost positive the Taurus GEM does not shut off all accessories for up to 45 minutes. You can shortcut it by touching the cable to battery, hook uo meter then separate cable from battery.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 03-30-2005, 07:27 AM
bbrd177 bbrd177 is offline
Greetings. I too have this problem. I've checked the dash switches, but the lite stays on sometimes. I'm curious to know how the lite knows the door is closed, as there is no visible door switch. Is there an internal door switch?
Old 03-30-2005, 08:48 AM
sfontain sfontain is offline
Door latch. You might try lubricating the latch in your doors.
Old 04-01-2005, 12:59 PM
GPFred GPFred is offline
I had this problem as well with the interior lights staying on. Turned out to be the door ajar switch in the door had gone bad. Ended up having to replace both.
Old 04-01-2005, 07:31 PM
chandler10 chandler10 is offline
I had the same problem. I lubricated the door latches with WD-40 and the problem went away.
