Old 04-14-2004, 11:42 AM
behvah78's Avatar
behvah78 behvah78 is offline
Cutout and cat-removal
Tell me what you think of this: An electronically controlled cut-out before the cat. Pipe attached to the straight branch and cat attached to the other branch and attached back together with a both end open cut-out. How many hp gains when on the straight pipe?
"Never drive faster than your Guardian Angel can fly."
[img]
http://us.f2.yahoofs.com/users/41b4f...__sr_/f414.jpg [/img]
Old 04-14-2004, 04:38 PM
Ripn12s's Avatar
Ripn12s Ripn12s is offline
Send a message via AIM to Ripn12s
Re: Cutout and cat-removal
why do all that work, just weld in the cutout and be done w/ it
Old 04-14-2004, 04:49 PM
behvah78's Avatar
Well the cutout is too loud to use on-road but this way i will have the cat off all the time except for inspection time.
[img]
Old 04-14-2004, 05:11 PM
Ripn12s's Avatar
With all the extra piping you'll be adding the extra weight will negate the extra ponies you'll get.
Weld in the cutout before the cat, put a qtec or mccord power plate on it. You can open and close it whenever you want.
Old 04-18-2004, 12:04 PM
kilroypr's Avatar
kilroypr kilroypr is offline
Send a message via MSN to kilroypr Send a message via Yahoo to kilroypr
I have seen people that put a small resonator at the cutout and that dissipates noise a little. I agree with Ripn12s to much hassle to just have a cutout. The electronic shut off is sweet tought. I would install the cut out with the electronic shut off and open and close it at will. That is sweet
Old 04-18-2004, 05:59 PM
GTPCatz GTPCatz is offline
Banned
I have heard and seen that there is no room before the cat to add a cutout....how do you plan on finding room for this?
Old 04-18-2004, 06:05 PM
behvah78's Avatar
No one has told me yet how much hps I'll get considering that I have already removed the ubent and resonator and I have good flowing mufflers. With the cutout I might also put a resonator to make it quite. Anyone thinks I'll get hps worth the effort?
"I have heard and seen that there is no room before the cat to add a cutout....how do you plan on finding room for this?"
Even if that is true you can always cut from the after and move the cat forward a few inch.
[img]
Old 04-18-2004, 06:46 PM
Ripn12s's Avatar
I went from 14.00s to 13.8's w/ all mods being equal except a cutout. So it helps.
Adding a cutout before the cat is possible. What you need to do is have a shop cut a whole in the pipe and then weld in the 3 bolt flange thing that the cap attaches to.
Old 04-18-2004, 07:40 PM
jeffs_GTP_sleeper's Avatar
jeffs_GTP_sleeper jeffs_GTP_sleeper is offline
Re: Re: Cutout and cat-removal
I thought the 97-03s had room but I do know it would be very difficult on the 04s because the cat is moved way forward.
04 Downpipe
Old 04-18-2004, 11:47 PM
kilroypr's Avatar
The only way to do it on 04 is to move the cat after the little bend and on it's place do the cutout
2000 Tahoe LT Fuel Pump, Cats and Door Actuator ediesel_b13 Tahoe 0 05-14-2010 10:36 AM
Exhaust cutout???? and it sounds good????? bag91 Camaro Discussions 5 07-19-2006 06:30 PM
92 Tracer wagon (same as Escort?) fuel cutout and brake lights came on... dghawk Escort 5 11-23-2004 10:05 AM
cat removal rkturbo 240Z | 260Z| 280Z | 300ZX (Past Z Cars) 9 03-09-2003 12:05 PM
Cat removal raptor Performance 7 11-19-2001 01:56 PM
