Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Suspension
Suspension setups, shocks, springs, tires, handling.
Old 01-11-2002, 02:20 AM
OG20's Avatar
OG20 OG20 is offline
Ok Another GC setup question...
Hi I just bought a set of GC's 350front/250rear sounds typical but I made them all 7" springs all around. I noticed that people with the 8inchers up front still have a pretty big gap even at the lowest setting thats why I opted with the 7's. I haven't installed them yet but they'll be set up with a set of AGX's. I also have a pair of 8" 250's and a pair of 7" 325's. Here's my question. Should I run the 350/250 or swap the front springs and run 325/250? I noticed some people complaining about the jiggling with the stiffness of the 340's. I'm currently running crappy intrax springs that have sagged to tuck my front wheels. I changed the bumpstops to progressive foams and that helped tremendosly. So any thing else would be much better. I noticed that people who went from stock to intax to GC's are all satisfied but the ones that go from stock to GC's are slightly concerned about "jiggling". I was just curious on everyones opinion on which springs should I use. My goal height is to have about a finger or flush up front and a finger or two in the back. You guys are quite experienced with these coilovers so please be technical and list some pros and cons.
Old 01-11-2002, 04:50 AM
P10DET's Avatar
P10DET P10DET is offline
Re: Ok Another GC setup question...
<snip>
Well, that's odd because I have7" springs up front absolutely as high as they will go, but still only have the gap you specify.
I personally would try the 325 springs up front first. The jiggliness comes from the dampers not totally controlling the spring oscillations. You can get it damned close, but I didn't like the 340s. I might have been able to get it better with more dinking around with damper settings, but I like the 275 s much much better. I just need to get the Koni bumpstops.
George Roffe
Houston, Texas USA
00 328i
91 SE-R (well modded)
84 944 SCCA ITS race car under construction
"I fear all we have done is to awaken a sleeping giant and filled him with a great resolve"
-- Admiral Yamamoto, December 7, 1941
Old 01-11-2002, 02:01 PM
OG20's Avatar
Any other opinions?
I was also wondering how people are gauging the spring rate ratios front and back and how this might affect my steering (ei. oversteering or understeering) thanks, cel
Old 01-12-2002, 10:17 AM
JustinP10's Avatar
JustinP10 JustinP10 is offline
Send a message via ICQ to JustinP10 Send a message via AIM to JustinP10 Send a message via Yahoo to JustinP10
I bought my GC's in a group deal about a year and a half ago, and that's the recommended setup by GC, and also a good friend of mine. He was the one that prototyped the GC setup on a P10, and i guess they found that spring rate to be the best? After riding in his car, i decided to go with the same setup, as i was very happy with both the ride and the handling.
Also, Geo, with a 7" spring, when the suspension is fully compressed, is there any coil-bind? (I think that's the correct term for it?) Also, is it correct to assume that an equal spring to mine (8"), but in an inch shorter size (7") would just move the spring perch up 1" (i'm sure it'll vary a little bit), or are there other factors that would afffect how far the spring perch would need to be moved to get an equal ride height? Thanks
Justin McClanahan
95 G20
15.4 @ 91.4mph (2.4 60ft )
143.7whp and 131.4 ft.lbs
Primera (10:1) Intake Cam, HS CAI, HS Header, UR Pullies, 19* Timing, ACT, Lightened Stock Flywheel, GC/AGX, Pacesetter Short Shifter, and more stuff...
Old 01-13-2002, 09:40 PM
OG20's Avatar
SO justinG20 you're suggesting the 350/250 setup right? Or do you think I can pull off the 325/250 setup? What agx settings are you using with your 340/250's?
Old 01-13-2002, 11:24 PM
JustinP10's Avatar
I am currently running 2/2 on my agx's. Between the two setups, it would depend on how low you want to go?
As for the difference between the two setups, do you think you would really notice 15lbs? I know for certain the 340/250 setup is a very neutral, nice setup on a G, so I'd recommend it, but if your looking to go softer, i'd probably go softer on both ends of the car, and not just the front. But i'm not sure where to start looking (as far as spring rates) if you want softer springs. And the biggest factor would be how low you want to go..... that ultimately determines the optimal spring rate.
Justin McClanahan
95 G20
audio setup question cody911911 Car Audio 17 05-14-2004 04:46 PM
Type R Head Setup Questions?? speedracing Integra 4 03-27-2004 10:11 PM
Twin Turbo Setup Question Jedi276 Mustang Talk 14 01-30-2004 01:16 AM
Setup Questions 1ARACE Mustang Talk 14 01-28-2004 06:02 AM
turbo setup question delB18sol Forced Induction 1 05-02-2003 01:10 PM
