Old 01-26-2004, 01:02 PM
1ARACE 1ARACE is offline
Setup Questions
Its winter time and its time to up the hp before spring. Problem is I'm having trouble deciding which way to jump before I dump the cash...been doing a lot of reading, researching and talking to stang gurus but now i'm stuck. Here's the scenario:
-95 GT/vert - 23k miles -stock engine -AOD -bassani x-pipe -flowmaster exhaust -255/35 yokohamas
Got a good deal on a vortech s-trim...but before it goes on im building the upper half of the engine first (h/c/i)
For budget I was looking at the package deal summit offers with the holley systemax kit or the trickflow kit. I read some good reviews on the tw heads and track heat intake for the trickflow. Haven't heard much on the systemax though. I was gonna go with the AFR 185's but would be more expensive by time I buy cam/intake/rockers etc. But maybe its worth the extra $$$ to get AFR's or will I be happy with the trickflow/holley kit? I'm also increasing airflow by getting BBK longtube headers as well to finish off my exhaust.
stock AOD = = to be removed. Looking into getting a tremec tko but having problems finding a good place to get the conversion kit from...funny the conversion kit costs more than the tranny from one place i seen it (ampperformance.com). Does the conversion kits come with the clutch? and if so are they any good? (just wondering...if anyone else has done a AOD-manual swap could enlighten me). Tranny cooler will be installed and 3:73 gears.
Switching to 30lb injectors, 255lph in-tank pump. MSD 6A, 8.5mm wires.
Local stang guru that is going to help me with this big job said stock block/crank/pistons will hold the power since only 23k on engine. Future plan would to be to stroke it to 347 and run forged interals...but not this year.
I'm also looking into suspension as well, figured might as well do it this year because I want to enjoy the power of the car and with low pro tires...traction and wheel hop may be a problem. Seen a lot of people running eibach...any recommendations for keeping the tires planted? any good kits available?
On a side note...with this sort of setup...how much boost should be ran? I was thinking between 9-15. I do plan on finding someone to custom burn a chip and possibly get it on a dyno (soon as I find someone that is relatively close in NW Ohio).
This is the vision i've been tossing around and to me it seems like it will work good...but i'd love from some experienced stangers. I've been reading so many forums, reviews, and ad's that my eyes have rolled back in my head and now I feel confused on which way to jump .
Thanks for taking the time to read this big post and thanks for any feedback you can offer.
Heres some eye candy after reading all this...so here's my stang.
Old 01-26-2004, 02:30 PM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
See, here is the thing. There are so many options to get the same result.
I would go with a TFS stage 1 cam, 1.7rr, 185 AFRs, track heat intake or Edle RPM. Then the S-Trim.
If you are going to put all that on a 347, I would upgrade the block as well. If you are putting that much power, it would only be a matter of time before you split the stock block.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 01-26-2004, 02:42 PM
SkylineUSA's Avatar
The Holley Systemax is the same design as the Vortech, and the Saleen. Its not bad, but there are better. I run the Vortech intake, but then again, my engine was built back in 96.
Old 01-26-2004, 08:49 PM
...say what?
Old 01-26-2004, 10:47 PM
eillob's Avatar
eillob eillob is offline
Nice stang
Ported Cobra Intake, Ported & polished Windsor Jr heads, K&N, Vortech s-trim, 90mm Lightining mass air meter, 70mm throttlebody,1.7 roller rockers, BBK Long tube headers, offroad H-pipe, Crane cam, main cap girdle, 40 series flowmaster, 3.73 gears, MSD ignition, CGS subframes, A9L PIH kit, SCT custom burned chip, 42lb injectors, 190lph fuel pump, T rex and fuel pressure regulator, AFCO racing radiator
(If it doesn't scare the Hell out of you it isn't fast enough)
Old 01-26-2004, 11:55 PM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
for some real nice traction, get some upper/lower control arms and some stiffer springs to start. then get shocks/struts, subframes, etc.
you said you wanna put a cooler on the auto right?
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 01-27-2004, 03:29 AM
SkylineUSA's Avatar
Re: Setup Questions
Originally Posted by 1ARACE
...say what?
Yep, the same. Its also the same as the Weiand Stealth as well.
Old 01-27-2004, 02:05 PM
Anyone know much about the conversion kits that are out there?
I figured spending the extra money for the AFR route would be a good idea...just looking for feedback on the TF/Holley kit offered...figure if I can pull about the same hp and performance as the AFR route it would save me some $$$. I know i'll have to notch the pistons for the 185's for clearance...pretty sure wouldnt have to with the 165's/TW/Holley heads tho.
See heres the thing tho...if I was going to stroke it and run forged internals...wouldn't it be better to just buy a crate motor? Because I would be basically rebuilding the entire thing anyway. I've looked around at some crate motors...but have'nt found one that runs forged internals. This is why im not sure which way to jump....because I really cant tell how long the stock block will last with this setup...I know it depends on how you drive it...but I don't really ever beat the shit out of my stang...I just tromp on it when I'm being challenged by other cars other than that I just cruise it during the summer. I have 24k miles on the car now...the stock block/crank/pistons could last to 100k or it could take a shit 10k miles down the road...so I guess this is just a case of pay me now or pay me later huh?
...and I haven't ordered anything yet so I'm trying to decide the most reasonable route to go and save a little money where I can.
my visa -> <- me
Old 01-27-2004, 02:37 PM
SkylineUSA's Avatar
Any of the crate engines you see, can be built with forged internals, you just have to ask.
What do you care about when it comes to the car? Just beating the other guy? When you get into that game, it will always come down to has the deeper pockets, most of the time.
Old 01-27-2004, 02:58 PM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Re: Setup Questions
If it were my car, here's what I would.
Motor with stock bottom end, seeing it still has low mileage;
Edelbrock Performer II intake
AFR 165 heads (no piston notching required)
1.6 rr's
New lifters, pushrod and ARP head studs.
Crane 2030 cam, or TFS stage 1(50 state legal)
75mm MAF meter
70mm TB
Pulleys
3 core radiator
190 LPH fuel pump
30 lb-hr injectors
adj FPR.
For the tranny;
3000 rpm stall converter
Trans cooler
Quality shift kit or manual VB.
3.73's in the rearend, or 4.10's with good traction
Alum driveshaft
With all that done, you will have roughly 325-350 BHP and a car that should be able to run very low 13's, and maybe even high 12's with good driver and traction.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 01-27-2004, 04:47 PM
SkylineUSA's Avatar
But, the 185s would give him room to grow later, since he wants to go FI.
But, I do agree with ya. That is a good solid combo, but there are a lot of those in the Mustang world
Not like back in the day, when your only power option was to port some old 351W heads Yes, I am old.
Old 01-27-2004, 05:06 PM
HiFlow5 0's Avatar
Stanger
Re: Setup Questions
Come on now old timer, things are much better now then they were back in your day! LOL
-2013 Ford Flex
-1999 Ford F150
Old 01-27-2004, 05:19 PM
HiFlow -- would underdrive pulleys do much of anything with a s/c on it? cause i have a vortech s-trim.
Wouldnt it be better to just run a 255lph pump?
Wouldnt the stock lifters still be good to run?
The s/c comes with the t-rex inline fuel pump...would i need a adj. fpr? if so what for?
Thats good advice HiFlow and Sky...thats pretty much the original way I was gonna go before I ran across those combo kits in summit....see the great thing about summit is if you order over $500 you can get 0% apr for a year on their speed card...which is pretty nice imo.
...and i'm still not sure if 185 or 165 AFR's are the way to go....true you dont have to notch 165 but for like $20-30 more you can get 185...dont you think its worth it?
I'm still looking for info/feedback on conversion kits...nobody has heard about people who has bought them? any thing to watch out for.....the AOD -> manual swap is what i'm most leary about...i dont want to get screwed with some junk ass conversion kit and regretting i bought it...know what i mean. The rest is pretty much bolt on and you know what your getting, but I know there are diff types of conversion kits out there....i'm just not sure which are the reputable ones ya know.
Thanks again for the feedback.
Old 01-27-2004, 11:44 PM
SkylineUSA's Avatar
If your going to boost, I would not even consider 165s. They will bottle neck the engine.
HiFlow,
That hurt
Old 01-28-2004, 06:02 AM
HiFlow5 0's Avatar
Stanger
Re: Setup Questions
HiFlow,
That hurt
True dat about the 165's if blown. I'm not sure if a 255 LPH fuel pump will be necessary if your running a T-rex and an adj. regulator. Pulleys should be fine even with a s/c set up.
Come on Skyline, you know I was only joking with ya? My birthday is in 2 weeks, I feel pretty old myself! LOL
-2013 Ford Flex
-1999 Ford F150
audio setup question cody911911 Car Audio 17 05-14-2004 04:46 PM
Type R Head Setup Questions?? speedracing Integra 4 03-27-2004 10:11 PM
Twin Turbo Setup Question Jedi276 Mustang Talk 14 01-30-2004 01:16 AM
turbo setup question delB18sol Forced Induction 1 05-02-2003 01:10 PM
Ok Another GC setup question... OG20 Suspension 5 01-13-2002 11:24 PM
