Old 01-26-2004, 02:32 PM
Jedi276 Jedi276 is offline
Twin Turbo Setup Question
Hey Guys,
I know there arnt too many people here running turbos on their mustangs, but I figured I would ask about it anyways. I have always been dying to turbocharge my '01 GT, and come may I will have about $5k to work with. At first, I decided I would drop in a SHM forged shortblock and build up the rear end, and wait for a later time to do the turbo setup. However, it just came to mind that running around town in a low compression engine without the turbo on is going to suck bad. So now I am considering putting a twin turbo kit on the stock engine, running low boost until I can afford to put in the forged block. What do you guys think? Also, what amount of boost can safely be run on 91 octane gas? Thanks for the help.
Old 01-26-2004, 03:05 PM
boosted331 boosted331 is offline
Re: Twin Turbo Setup Question
I wouldn't go for more than 8 psi on a stock 4.6 2V, 91 octane or race gas. I think it's a good choice to go with the turbo kit first, you'll have a lot more fun with it.
Old 01-26-2004, 04:55 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
Re: Re: Twin Turbo Setup Question
Totally agree, you could go as high as 11psi with a liquid aftercooler set-up
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 01-26-2004, 05:00 PM
Re: Re: Re: Twin Turbo Setup Question
Provided you like picking up snapped powdered metal connecting rods out of your oil pan, then sure! 8 psi I would feel safe from, but 11 psi, especially 11 psi from a turbo, and your motor is on borrowed time. It isn't a question of IF it's going to break, it's when it's going to break.
Old 01-26-2004, 05:14 PM
GTStang's Avatar
Stang Guy
I think the stock 2V can handle 11psi with reliability. I've seen it done with S/C maybe with a Turbo it will be enough to run into a problem.
Old 01-26-2004, 07:19 PM
Hypsi87's Avatar
Hypsi87 Hypsi87 is offline
I got your v-8 swingin!!!
Send a message via AIM to Hypsi87
IMO iinternals are a secondary. My main consern with any force fed car is pre-deationation. Deffinately need a BIG front mount or an air to water intercooler. Alcohol injection helps alot.
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
Old 01-27-2004, 12:07 AM
Cobra01TT's Avatar
Cobra01TT Cobra01TT is offline
www.inductionconcepts.com is where I'm going to get my twin kit, and most of the people on those forumn say don't go over 500 hp with stock internals. The Cobras can go a little more b/c of the forged crankshaft. You will definitely need to get forged connecting rods and maybe forged pistons. It would also be a good idea to get lower compression pistons.
2001 Ford Mustang Cobra - Straight piped and loud as hell
2002 Yamaha R6 - Micron exhaust
1987 Chevy Corvette Convertable A.K.A. - The Pimpmobile
Old 01-27-2004, 12:19 AM
Hypsi87's Avatar
My 5.0 is at the fab shop getting custom stainless headers/piping made up for my TT setup. Ill have to get some pics posted.
Back in action!!!!
1999 Ford F-250
ASE Certified in...
Mobile AC
On highway trucks.
Member of
Old 01-27-2004, 01:39 AM
I don't think you understand how laughably weak the 4.6 2V's internals are. Like I said, anything more than about 8 PSI or 400 RWHP and atleast one of your rods are going to feel the need to bust apart. Detonation isn't an issue with a calibrated MAF, some 42's, and a chip, weak internals are an issue.
Old 01-27-2004, 03:25 AM
GTStang's Avatar
Stang Guy
I agree with you the 4.6 2V is weak but not that bad. Vortech and Kenne Bell both make S/C kits that are made for stock 4.6 2V engines that are pushing 390 to 425 hp at the rear wheels. Both these kits are designed to make those numbers w/o puking stock rods and motor last 100,00miles. 9 and 11psi respectively.
Old 01-27-2004, 08:58 AM
DDMTK421DS's Avatar
DDMTK421DS DDMTK421DS is offline
Send a message via MSN to DDMTK421DS
I have a Vortec Supercharger..(5-9 psi).......It rocks, I gained 130 Hp with it, (stock 245hp-to new 375hp) with the help of new 30lb injectors, Nre throttle body, Vortec Fuel pump, fuel pressure Regulator, and a few other small parts.......
Total cost about 5-$6,000 with labor.....
Obviously it wasn't fast enough for me so I am now Dropping the stock motor for a totally new One.....It's in the shop right now. I miss her.....
Old 01-27-2004, 03:06 PM
Neither Vortech nor Kenne Bell have come out and said that a 4.6 2V will last for 100K miles with 400 RWHP, because it won't. If you could get the motor to last for 10K miles feeding it 11 pounds of boost, I would be impressed. Anyone I have seen making that much power on stock pistons/rods has either busted the rods or shattered the ringlands. Trust me, stick to no more than 8 psi on a stock motor.
Old 01-27-2004, 04:46 PM
GTStang's Avatar
Stang Guy
I just disagree here Boosted..... I think your very intelligent but here we just believe different things. I deal with Vortech Engineers(not salesmen) a lot and talk to them at least once a week. They spend a lot of time creating kits and programs for each individual car so that it will not destroy the engine. If Vortech went around selling kits tailor made for cars that was blowing them up 10,000 miles later they would not be in business still and be #1 selling name in Mustang S/C market.
We have a 02 Rousch Stage 2 that has a Vortech liquid aftercooled S/C kit that I installed running at 10psi. That is a stock 4.6 2v block and the car has 7,000 miles on the since install and 12,000 miles total so we will see if it will make it to 10,000 my money is it will and many miles more.
Old 01-30-2004, 01:07 AM
runningmole runningmole is offline
Send a message via AIM to runningmole
www.turbochargedpower.com
1993 Mustang GT
Blue/Titanium 2tone, 5spd, 3.55s, JBA ceramic shorties, catted H-pipe, dumped Magnaflows, MSD goodies, FMS alum rad, Pro50, balanced/blueprinted forged 327 stroker (8.2 compression), AFR 185s, Performer RPM, 70mm TB, FTI custom cam, SFC, In-floor Subframes, Maximum Motorsports Torque Arm and Panhard Bar, H&R Springs, Bilsteins, MM CC plates, 5 Lug Conversion w/ Silver Bullitts. Full accessories including smog legal. 310rwhp 351rwtq Dyno Dynamics Dyno. Soon to be supercharged
Old 01-30-2004, 02:16 AM
fatninja19 fatninja19 is offline
Send a message via AIM to fatninja19
Hurry up with the pics!
when in doubt, throttle.
3rd gen twin turbo setup on 2nd gen non turbo 13b? EnjukuRacing240sx RX-7 2 11-17-2008 06:15 PM
Looking for twin turbo setup VR43000GT 3000GT/Stealth 1 12-26-2005 10:09 PM
1985 Twin turbo setup 300zx_racer 240Z | 260Z| 280Z | 300ZX (Past Z Cars) 2 05-31-2004 01:23 PM
Help looking for twin turbo setup lonny24 Camaro Discussions 7 03-07-2004 11:44 PM
wierd Q about a twin turbo setup raven_240 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 17 01-16-2004 08:00 PM
