Go Back   Automotive Forums Car Chat > Mitsubishi > Galant
Old 04-11-2004, 11:34 PM
Asianprep Asianprep is offline
car is making a squeking noise....
My car have been making a squeking noise for a whilez now. Everytime i make a turn or a slight turn it makes a high pitch squeking noise. I thought i need to change my belt but it's pretty brand new. i went to auto zone and a rep checked my car and it might be my ac bearing....any suggestions guys??? i need to be cheap since i'm a poor
Old 05-31-2004, 03:06 AM
gmech gmech is offline
Re: car is making a squeking noise....
Probably one of three things. suggest checking in the following order.
1. Check the power steering belt for proper tension. A good guideline is you want the about 1/2" slack both up and down direction.
2. Check the P/S fluid for proper level.
3. *** Check the harmonic balancer for possible seperation. The balancers are known for seperating causing a high-pitch squeal. The rubber seal between the outer and inner piece on the harmonic balancer over time can begin to seperate, resulting in misalignment of the outer pulley connected to the balancer.
Old 03-20-2005, 12:08 AM
gotricematt gotricematt is offline
hey i have the same problem with my galant. did u find out the problem?
Car makes gasping noise when shutting off (under hood) 90gs Integra 10 12-20-2007 06:05 PM
Car making loud noises! kgodwin3 Lumina 8 10-21-2004 06:52 PM
help...car makes strange noise :( Vincyv439 Integra 1 12-18-2003 05:28 PM
car makes rattling noise mindajatt 3 Series 1 12-15-2003 10:12 PM
car makes screeching noises 91hondaguy '88 - '91 Civic | CRX | Wagon | Shuttlee 8 02-18-2003 10:52 PM
