Go Back   Automotive Forums Car Chat > Honda > Integra
Old 05-18-2003, 05:59 PM
90gs's Avatar
90gs 90gs is offline
Send a message via ICQ to 90gs
Car makes gasping noise when shutting off (under hood)
ok ive been trying to take my catalytic convertor off for a while but never had anything but a POS socket wrench, so today i went out and bought a breaker bar.
i jacked up the car and took off both front tires so i could access the bolts i needed to take off. i sprayed WD-40 all over the bolts and let it sit for a few minutes then went to work, i snapped off the first bolt with minor effort (cranked on breaker bar and the bolt snapped) and then i realized that i'd need new bolts after putting in the test pipe. so i decided to wait until i got new bolts before i took off the rest of the bolts so right now theres the 3 bolts connecting the cat-back to the cat and 1 bolt connecting the cat to the downpipe (remember 1 bolt is broken) now my car makes a rather large gasping noise when i shut it off. that is air rushing into the header right? is that a bad thing? as long as i dont shut off the car while the revs are dropping i wont crack the head will i?
Old 05-18-2003, 09:58 PM
sameintheend01's Avatar
sameintheend01 sameintheend01 is offline
Send a message via AIM to sameintheend01
Re: Car makes gasping noise when shutting off (under hood)
why do you need need bolts with the test pipe? if you are so worried, just take the cat off for a couple days. i don't think you could crack the head from air pressure left in the exhaust system.
Clear Corners
Front and Rear Strut Bars
Cold Air Intake with K&N filter
Iridium Spark Plugs
High Performance Plug Wires
High Flow Cat (unistalled)
Cool high/low beam lights
All around slotted and AEM pads
Old 05-19-2003, 01:14 PM
91civicDXdude's Avatar
I think he means he has an exhaust leak now. It shouldn't really hurt anything besides sound crappy. Hurry and get it fixed though.
Old 05-19-2003, 05:42 PM
90gs's Avatar
yea ima buy some new bolts and get that sealed up and once i have the money ill buy a bomz high flow cat and put that on there in place of the stock cat..
Old 05-23-2003, 10:47 AM
GSR GSR is offline
Send a message via AIM to GSR
leave the cat on there until you have a replacement. if you leave it open header you run the risk of bending a valve
looking for a 95+ 240sx in/near D F Dub area
Old 05-23-2003, 04:27 PM
90gs's Avatar
i wont risk bending a valve if i have a test pipe though right? im deciding between BOMZ high flow cat and a test pipe. i hear that the BOMZ high flow cat is just a resonated test pipe and resonation makes it sound deeper.. i dont like ricey sound so im thinking ill do that
Old 12-01-2007, 02:00 AM
ProShift ProShift is offline
I dont think it has much to do with your exhaust, I would check your pcv valve
THE ONLY CARBS ANYONE SHOULD CARE ABOUT IS UNDER THEIR HOOD
Old 12-09-2007, 03:39 PM
ZedEx's Avatar
ZedEx ZedEx is offline
GO-FIGHT-KILL!
Send a message via AIM to ZedEx
It's just the engine turning down. Do you have an intake? Have your friend shut the car off, while you're standing in front of the car with the hood open. Listen to your intake, I guarantee you that's where the noise is coming from.
Both my Type-R and Prelude do this.
-2000 PY Acura Integra Type-R #686 - WhoRe
-1997 EGP Honda Prelude Type-SH - Daily driver
R.I.P Hypsi87:Andy Filson
Old 12-10-2007, 01:03 AM
Twizted_3KGT's Avatar
Twizted_3KGT Twizted_3KGT is offline
Sounds like it's just your intake to me. My Integra did this, my buddies Accord does it, and pretty much every car with a cold air intake i've seen does it. You won't be bending valves from having an open header. AFAIK that's just an urban myth involving cold air entering through the header and warping the hot valve...highly highly highly unlikely.
1997 Mitsubishi 3000GT VR4 - 269AWHP/290AWTQ (Mustang Dyno) - [email protected] - 1.756 60ft. - [email protected] (Best TDO4-9B Time) - Driver Mod - IPS TD04-19TL - SPEC 4+ - Wiseco Pistons - 3SX Custom Forged Rods - PMP FMIC + Much More.
Old 12-10-2007, 07:36 AM
ZedEx's Avatar
GO-FIGHT-KILL!
^ Pretty much.
Not even necessarily a cold air intake, even an open throttle body will do it. Just any aftermarket intake in general, I think even the Comptech Icebox does it.
Running open header will not damage anything.
Old 12-20-2007, 05:05 PM
Ascendance Ascendance is offline
Banned
That's the first thing I thought too, my intake does this.
