Go Back   Automotive Forums Car Chat > Honda > Integra
Old 12-18-2003, 09:39 AM
Vincyv439 Vincyv439 is offline
help...car makes strange noise :(
Allright...so this hasn't happened before but a few days ago my 97 Teg LS started making these noises...uum...sounded like it was coming from the Cat Converter...but not really sure cause I haven't even began to mess with that stuff. (newbie) Usually gets really loud when I gas up to 1800 rpms...what do I do?
Old 12-18-2003, 04:28 PM
ManOnTheGo's Avatar
ManOnTheGo ManOnTheGo is offline
Re: help...car makes strange noise :(
Most catalytic converters make a repetative dinging sound when you first start up the car or when you stop the car. This is due to the expansion and contraction of the different materials and it's normal.
If the sounds are more like clanging noise, you should look under your car for loose fasteners.
If the noises are really loud, check for corrosion on the muffler, the catalytic converter, and the exhaust pipes.
Hope that helps.
If not, please provide more details of the noise, when the noise occurs, and if the noises can be consistently reproduced. Also provide the environmental conditions.
