Old 02-17-2003, 03:27 AM
91hondaguy 91hondaguy is offline
car makes screeching noises
Hi, one day all of the sudden
my car ( engine) start to make Loud SCREECHING NOISES
especially when i engage 1st gear and start to drive , then after i drive it for a while it stops, till the next time i stop and go again.
please tell me what is going on with my car
and reverse also..
i own a 88 yellow CRX
www.northwestshowoff.com
Old 02-17-2003, 03:29 AM
GTA's Avatar
GTA GTA is offline
Whee..
check your alternator belt, it might be loose. or maybe other belts if you have any more...
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 02-17-2003, 03:39 AM
Civic Jim's Avatar
Civic Jim Civic Jim is offline
Send a message via AIM to Civic Jim Send a message via MSN to Civic Jim
More than likely, sounds like its a belt
Jim - Your Resident EDM Biatch
B16A1 I/H/E
4TH GEN UK SITE
Honda Civic EE9 1.6-i VT
Old 02-17-2003, 05:57 AM
dylly dylly is offline
I had the same trouble last week. It has something to do with the cold weather but the belt is too loose. All you need to do is tighten the belt. Start by loosening the bolt on the sliding bracket of the alternator. Now you can move the alternator further away from the engine which in turn will tighten the belt.
Old 02-17-2003, 10:19 PM
hi
Ok , so you think its my belt that is loose
i have a 1989 honda civic cx stock
so please tell me step by step how to repair this problem
thank you very much
its gets annoying
Old 02-18-2003, 09:21 PM
hi
ok . what is it gonna take on installing a
89 CRX ENGINE WITH 95 CIVIC SI TRANNY
to my
1989 Civic CX
same as any other d series swap
nuthing really special about it
rite?
Old 02-18-2003, 09:29 PM
plkelley's Avatar
plkelley plkelley is offline
Send a message via AIM to plkelley
I dont know shit about the 95 trannies but if there the same as the 4g then it will be a real simple install. But while you have the engine out you may as well replace everything possible. Belts, water pump, clutch if needed. Its alot easier to do that stuff with the engine out of the car.
Old 02-18-2003, 09:48 PM
GTA's Avatar
GTA GTA is offline
Whee..
the 95 civic tranny is a hydro tranny, you'll have to convert it to cable to use it.
AF Bay Area Crew
RIP Melt
2007 Toyota Prius
I <3 and miss my 4g
Old 02-18-2003, 09:52 PM
plkelley's Avatar
Well that definetly make it a little more complicated, 4g Si trannies arent too expensive are they?
Car makes gasping noise when shutting off (under hood) 90gs Integra 10 12-20-2007 05:05 PM
car makes screeching noise GTPSPEED Eclipse Problem Diagnosis 1 06-14-2005 07:21 PM
Car making loud noises! kgodwin3 Lumina 8 10-21-2004 05:52 PM
help...car makes strange noise :( Vincyv439 Integra 1 12-18-2003 04:28 PM
car makes rattling noise mindajatt 3 Series 1 12-15-2003 09:12 PM
