Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 04-11-2004, 10:21 PM
nxtnlin nxtnlin is offline
Question Trans clutch line?
I'm tring to swap the 5-speed transmission in my 1992 Ranger. Can someone tell me how to get the hydraulic line that operates the clutch disconected?
Old 04-12-2004, 01:18 PM
whitelimo55 whitelimo55 is offline
Re: Trans clutch line?
should be similar to the 95 i just pulled. the line disconnects at the transmission. it separates like a fuel or a/c line. there is a plastic sleeve around the inside of the connector. push it all the way in with a fuel line disconnect tool and the fitting should pull out.
Old 04-12-2004, 01:49 PM
Thanks. I'm about to go back out to try again. I'll let you know . Have a good day.
Old 04-12-2004, 07:06 PM
There is a tiny little roll pin holding the line to the slave cylinder. I drove it out and the line was free. Thanks for your post.
clutch problem..i think bov3220 Engine, Transmission and Drivetrain 4 05-22-2009 12:17 PM
Rusted out trans oil lines and dif howl pretz99 TrailBlazer | Trailblazer EXT 4 01-05-2005 08:22 AM
leaking clutch line freakonaleash1187 240Z | 260Z| 280Z | 300ZX (Past Z Cars) 10 08-11-2004 01:39 PM
slave cylindar and clutch line... Jeep Comanche General Discussion 0 06-15-2004 06:07 PM
Ranger clutch line removal nxtnlin Engineering/ Technical 1 04-13-2004 01:07 AM
