I bought a used 02 Tb before I found this forum (major ooops). One week after I had it the trans oil cooler lines rusted out at the first bend and blew oil everywhere. The dealer said that was weird, never seen oil lines leak like that and then proceeded to charge me full price (since the warranty is off).
My rear end dif has quite a howl when I accelerate, and the dealer (same) says it is not a big deal. Is it o.k. to put some heavier oil in there? Thanks |
Probably wouldn't hurt to put in a heavier multiweight gear lube, but what I've seen over the years, won't do anything for the noise. You have a bad gear match in the ring and pinon, not unusual but sure a nuisance. Sounds like you might have gotten a really well used TB, maybe an early lease vehicle. Hope you have better luck with it than the initial impression
Re: Rusted out trans oil lines and dif howl
This is what you should be using SAE 75W-90 Synthetic Axle Lubricant (GM P/N 12378261, Canadian P/N 10953455) or equivalent meeting GM Specification 9986115. As far as the noise you hear, if it is happening on or during acceleration the most likley cause ia a ring and pinion concern (misadjusted backlash or worn gearset) If this noise is all the time and changes with speed, I would look towards a bearing problem
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again? Got all the certifications 25 years ASE Certified Master Technician GM WCT Yea..I work at a DEALERSHIP....got a problem with that? Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality) This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video PM Me for details |
Re:Rusted out trans oil lines and dif howl
Heard of this in several TBs. Seems the rear springs have a harmonic frequency that creates this noise. Dealers were replacing these springs under warranty for a while, probably cost you for this now. Might research in this direction some. Get you started:
http://www.mytrailblazer.com/shared/...2&REPLYCOUNT=3 |
