Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 08-07-2004, 11:26 PM
freakonaleash1187's Avatar
freakonaleash1187 freakonaleash1187 is offline
Send a message via AIM to freakonaleash1187 Send a message via MSN to freakonaleash1187
Unhappy leaking clutch line
well, tonight i was at a gas station and i turned my car on. i pushed my clutch in and it the pedal didn't come back out. WTF! car jerks and dies. i look under my car and see something leaking. i look at my clutch fluid resvoir thingy and i am all out. i go back under my car and it is clutch fluid. so i drive home in second gear the whole way. can't move it in or out of gear while the car is on.
i think i found the leak, it is coming from the hard line that goes down the passenger side wheel well in the engine bay. tomorrow i will find out exactly where it is and hope to hell i don't have to replace the hard line.
ZedEx Crew Member #2
Old 08-08-2004, 02:57 AM
Bluehydro8 Bluehydro8 is offline
Have you been clutching hard?..........Basically, have you been speed shifting or racing? because that will do it.
Old 08-08-2004, 05:24 AM
E Honda's Avatar
E Honda E Honda is offline
Send a message via Yahoo to E Honda
Re: leaking clutch line
Explain how these to things will have any adverse effects on the line?......The pressure in the line won't exceed the limits of the line under any driving conditions that us humans can dish out. and if hes speed shifting......well if doing it right.,,wont be using the clutch at all. so theres no pressure at all........I am just a lil curious and maybe I am about to learn something here.
Old 08-08-2004, 05:59 AM
ZedEx's Avatar
ZedEx ZedEx is offline
GO-FIGHT-KILL!
Send a message via AIM to ZedEx
Preasure is increased every time that clutch moves from its Equilibrium (or when it is at its "rest" stance)
So technically, yes, preasure does increase when you race, or put an abnormal amount of clutch initation... Either by frequency, or by flat out force.
See what im saying kind of?
But I think in Freaks case... It's probably just old lines.
Good luck getting it fixed buddy...
-Wes
-2000 PY Acura Integra Type-R #686 - WhoRe
-1997 EGP Honda Prelude Type-SH - Daily driver
R.I.P Hypsi87:Andy Filson
Old 08-08-2004, 09:28 AM
igota20hpweedeater igota20hpweedeater is offline
lol....it happened to me when i got done racing and shifting hard.
Old 08-08-2004, 09:34 AM
actually, when i was looking for the leak, the whole subframe which the line ran along is becoming corroded. so before i fix the leak, i am going to clean the subframe. don't want my fire wall or subframe (let alone my cluctch line) to be eaten away.
Old 08-08-2004, 04:13 PM
i found where it was leaking. the line that is on the passenger side, it is a bleeder line. it goes from the fire wall up to on top of the wheel well. there was a hole in the line. it was all corroded right by the battery. and the subframe and the battery tray has lots of corrosion on it. so i am guessing that one of the past owners had a battery blow and didn't clean the battery acid up. so the battery acid over time ate away at everything and finally ate completely away at the clutch line. stupid owners.
Old 08-08-2004, 05:58 PM
ZedEx's Avatar
GO-FIGHT-KILL!
Ahhh so I was right... I feel smart now
-Wes
Old 08-09-2004, 12:10 AM
longlivetheZ's Avatar
longlivetheZ longlivetheZ is offline
Send a message via AIM to longlivetheZ Send a message via MSN to longlivetheZ
That would be my guess. Battery acid is a naaaaaaasty substance. I had a battery tip over on my passenger side floor mat in my old Z and it actually made all the fuzz come off my mat.......all that was left was this bald, wilted, corroded rubber patch on my mat. That sucked ass.
Anyway...if it's a small hole, try some JB Weld to seal up the hole. I had a friend of mine actually patch a hole in his RADIATOR with that shit and it held for quite some time. If it's a bit more extreme, you might have to replace the line, in which I can't help you man....never done that.
Who cares what's in your wallet...what's in your garage?
VG30ET in process of rebuild on left and my 88 300ZX NA, 2 Seater, 5-Speed...my 3rd Z31
Hope you can see the tiny pic...AF reduced the size limit!
Beer is living proof that God loves us and wants us to be happy. --Benjamin Franklin
Old 08-11-2004, 01:09 AM
Re: Re: leaking clutch line
-Wes
Nice job! Wes....... Pat on the Back.....
Old 08-11-2004, 01:39 PM
coz is the greatest. he is getting my a steel hard line that i thought was going to be about $50-100 for $14. i recommend people to go to coz for all their oem parts needs.
