Old 04-11-2004, 09:45 PM
nxtnlin nxtnlin is offline
Question Ranger clutch line removal
I'm tring to swap the 5 speed transmission in my 1992 Ranger, and I can't get the line disconnected that operates the clutch. Can someone tell me how to get this done?
Old 04-13-2004, 01:07 AM
pind pind is offline
Re: Ranger clutch line removal
if you look on the line, right where it goes into the bell housing, there should be a fitting. inside that fitting should be a plastic collar, possibly white in colour. Push that collar in, and pull out on the line at the same time, this should release the spring clip holding the line in, and allow it to be removed.
1992 ford ranger stx cluth question kokopelli85 Ranger | Courier 1 12-26-2009 04:57 PM
1995 Ranger Hydrolic clutch line quick disconnect 110578 Ranger | Courier 4 05-05-2007 08:01 AM
removal of a hydraulic clutch line for an F-150? the_B F Series 1 07-03-2006 01:47 PM
1995 Ford Ranger Clutch cable removal rackman Ranger | Courier 1 04-24-2006 04:30 PM
2000 Hydraulic clutch slave cylinder line removal BananaBomber S-10 1 01-08-2006 12:20 PM
