Old 04-11-2004, 09:47 PM
carterstuart carterstuart is offline
Help with auto door lock problem??
My door locks on my 1999 suburban seem to be losing power when trying to open my doors with the switch inside the car as well as the remote control. It works fine sometimes but it also will act like there is not enough power to make the locks go up and down, when it does this there is a clicking noise I hear under the the steering wheel area. I wouldn't think it is a fuse since it does work sometimes. Any help would be appreciated. Thanks. -Stuart Carter
Old 04-12-2004, 02:11 AM
amac209 amac209 is offline
Send a message via MSN to amac209
Re: Help with auto door lock problem??
the clicking is the relay. theres a good posibility thats your problem
Old 04-13-2004, 10:30 AM
Ketch Ketch is offline
Re: Re: Help with auto door lock problem??
or...the relay is clicking only becazuse there is not enough power from the battery to move the locks????? have you checked to make sure your getting enough volts with engine running. ?
Old 04-13-2004, 09:32 PM
It still loses power and makes the clicking noise while the engine is on. I just purchased a new relay and once it comes in I'm going to swap it out, can anyone tell me where the realy is located under the steering column and how to switch it out? Any help appreciated. Thanks. Stuart
Old 04-14-2004, 10:34 PM
moutnbykr moutnbykr is offline
I have a 97 sub, with the same problem. I can hear the relay clicking from somewhere under the dash. I hope you post your results of replacing. If you don't mind me asking, what was the price of the replacement?
thanks
shane
Old 05-25-2004, 11:23 PM
Johnn Johnn is offline
The REAL problem and how to fix it!!
I have a 1999 K2500 Suburban and have had the same problems that you are having. I am the Sales/Marketing Manager for a large motor coach company and had my Maintenance Manager look at the problem. After a quick inspection of the actuators in each door, he determined that the actuator motors had worn out!!! Chevrolet wanted $80 each for actuator and that was more than I wanted to shell out. I searched online and found aftermarket actuators at A-1 Electric (www.a1electric.com) for only $29.95 each. They arrived yesterday (all 4). We installed them last night and voila...all locks work with both the door switch and remote like the truck just left the factory!!!!!!
Good Luck.
Old 05-31-2004, 03:25 PM
HopkinsINT HopkinsINT is offline
Re: The REAL problem and how to fix it!!
Good Luck.
Can you tell me how to get the door panel off. The lock on the pax side door is sticking. Thanks
Old 06-07-2004, 10:15 AM
delucaj delucaj is offline
I have a 99 Suburban and the power door lock for the front passenger door does not work properly. (It moves very slightly). I assume the actuator needs replacement. I need help with removing the interior door panel. Does anyone know how to remove it?
Thanks
Old 06-14-2004, 10:09 PM
You will need to purchase an "uphosterly removal tool" for about $10 at an automotive parts store. There are approx. 8 plastic spined pins that stick into small gromets around the outer rim of the door panel. They are about 3 inches in from the edge of the door trim. SLOWLY & GENTLY pry each one of them out of their gromet to take the door panel off. Get a bag of 12 new pins and gromets (at your local Chevy/GM dealership...about $1 each) to replace the ones that you will break during removal and reinstallation, so that your door won't rattle.
Old 08-28-2004, 09:00 AM
actuators
I replaced the relay, hoping the easy and inexpensive fix would work. It didn't.
Out of the 5 doors, only the driver door locks/unlocks when the button is pushed. Are the actuators wired in series so if the passenger door actuator doesn't work nothing else behind it will work, or is it just a coincidence that the 4 would all fail at roughly the same time?
thanks
1997 JGC Both Mirrors move with auto door locks Booger121 Grand Cherokee | Grand Cherokee SRT8 2 05-19-2008 01:41 PM
1997 dodge grand caravan auto door lock problem kiblersandbits Caravan | Voyager 2 03-03-2006 01:13 PM
2004 - Help with auto door lock joe_charles CR-V 6 02-02-2005 09:47 AM
1998 Ram 1500 Auto Door Lock problem exner60 Ram Pickup | Ram SRT10 1 11-17-2004 10:33 AM
98 accord auto door lock problem sequeira Accord/TSX/Accord Hybrid 3 01-06-2004 05:38 PM
