Old 04-10-2004, 11:31 AM
paul7 paul7 is offline
97 astro hard shift
Hi. I'm having trouble with a hard shift between first and second gear on my 97 Astro with 100k miles on it. The engine light is on,had it checked only to find out I have a transmission problem. What a brilliant deduction! GM dealer suggested I have a transmission service which I did but did not help.
This problem happens only after the van is hot. If I turn it off for 2 minutes the hard shift disappears until 20 minutes later.
Any ideas what is going on and what the fix is?
Thanks
Paul
Old 05-10-2004, 07:56 AM
Hondacrf Hondacrf is offline
Paul, I have the same problem, 97 Astro 110,000 miles. I just had the dealer service the trans, flush, new fluid and fiter. It works a little better but still shifts hard after it warms up. Have you had any luck with a fix?.
Old 05-12-2004, 12:39 AM
nitrorc nitrorc is offline
Re: 97 astro hard shift
I had the same problem with my 98 chevy astro van. It does this after the transmission warms up. The dealer knows about it and the fix is a gasket kit 4.265 in the transmission. Part cost about $13.04, total cost to fix is about 323.00 dollars. Reason why they have to overhaul tranmission to install it. Sucks but has to be done, else live with the hard shifting. Hope this helps you....
Old 05-12-2004, 10:52 PM
trannyman52 trannyman52 is offline
are you mecanically inclined to check and do this fix if I give you the
information????? not real tough!! [email protected]
Old 05-30-2004, 07:14 AM
slimjam44 slimjam44 is offline
Need help with my Astro tranmission
Hi gbaum, I sent you an email regarding the same issue with my 98 astro van.
Thanks much,
John Wells
04 impala Shifts Hard when Hot, P1811,shifts hard,jerks chevymandan Impala | Impala SS 3 10-09-2011 04:42 PM
Gear selector hard to shift serge_saati Windstar 16 06-05-2009 09:57 PM
S-10 hard 1 - 2 hard shift joslinm Problem Diagnosis 5 03-09-2009 05:33 PM
95 sl hard shift and hard start wkmaylish SC/SL/SW 9 06-10-2005 12:53 AM
burst of thrust/ hard shift when auto tranny shifts into second gear ERIKbronx Maintenance 6 04-22-2002 12:36 PM
