Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Maintenance
Maintenance problems, fixes.
Old 04-19-2002, 06:50 PM
ERIKbronx ERIKbronx is offline
Send a message via AIM to ERIKbronx
Question burst of thrust/ hard shift when auto tranny shifts into second gear
Burst of thrust and hard shift(uncomfortable shifting) when auto tranny shifts into second gear, it feels like the motor mounts are gone, but they are in good condition. Do you think its a tranny problem? I just changed my tranny oil yesterday and the hard shift is still there, any solutions???
Remember auto tranny and motor mounts are good!
PLZZZZZZ Help
:monkeypis :badass:
25% Tinted Windows
Pop Charger(K&N)
PIAA Xtreme Whites
KYB Suspension
OBX B3 Exhaust w/Silencer
Remote Start
Stabilizer Bar
Throttle Tightened
& more to come!
Old 04-19-2002, 09:01 PM
boingo82's Avatar
boingo82 boingo82 is offline
Can't polish a turd.
Mine does the same thing. I always thought it was because I would give it lots of gas, then look at tach and go "whoa, those revs are high" and then let off on the gas right as it shifts, causing a sudden change in HP/torque.
Old 04-20-2002, 07:16 AM
poppy_morenito's Avatar
poppy_morenito poppy_morenito is offline
Send a message via AIM to poppy_morenito Send a message via Yahoo to poppy_morenito
I have same condition only when driving slowly then needed to hit the gas on the street. This problem was lessened with not Transmission fluid....
Now it only happens if I am doing less than 10 then hit the accelerator hard ......
93.5 G20
JDM SPEC SR20
JWT POP CHARGER
GROUND CONTROL/KYB ADJUSTABLES
17" VOXX MGR 205/40/17
Old 04-20-2002, 09:56 PM
Prolem Solved!
Thanx www.se-r.net for helping me solve my problem. It was my EGR valve it needed to be cleaned.
:monkeypis :badass:
25% Tinted Windows
Pop Charger(K&N)
PIAA Xtreme Whites
KYB Suspension
Remote Start
Stabilizer Bar
Throttle Tightened
& more to come!
Old 04-21-2002, 09:16 AM
WOW really maybe I can get rid of mine totally now .. How hard was it to do Eric ?
93.5 G20
JDM SPEC SR20
JWT POP CHARGER
Old 04-21-2002, 11:09 AM
It real easy to clean, all you need to do is buy some carb and choke cleaner and read this link... You can even do an easy test by removing the little hose between the EGR and BPT valve to see if thats the problem before cleaning. Go here and read more http://www.se-r.net/car_info/problem...d%20hesitation
:monkeypis :badass:
25% Tinted Windows
Pop Charger(K&N)
PIAA Xtreme Whites
KYB Suspension
Remote Start
Stabilizer Bar
Throttle Tightened
& more to come!
Old 04-22-2002, 12:36 PM
Ok thanks I will try that in the morning ...
93.5 G20
JDM SPEC SR20
JWT POP CHARGER
04 impala Shifts Hard when Hot, P1811,shifts hard,jerks chevymandan Impala | Impala SS 3 10-09-2011 04:42 PM
1978 chev (auto trans) wont shift into second gear jannap Silverado 5 10-07-2009 05:51 PM
1978 chev wont shift into second gear, automatic jannap Problem Diagnosis 1 09-30-2009 11:08 AM
why won't shift into second gear? birar Metro 20 10-04-2008 01:35 AM
Trouble shifting into second gear winner1981 Engineering/ Technical 16 10-12-2004 06:13 PM
