Old 04-09-2004, 09:21 PM
OzZySi's Avatar
OzZySi OzZySi is offline
Pearl white over primer...
Hi everybody!
I just bought some light grey Tamiya primer, and I'm planning on doing one of my next models in Tamiya pearl white. Will the White cover the light grey? I've had bad experiences with grey primer and yellow, will the primer show through the white too?
~OzZySi
"It's better to be a living dog than a dead lion"
Old 04-09-2004, 09:39 PM
SonyMobile's Avatar
SonyMobile SonyMobile is offline
Send a message via AIM to SonyMobile Send a message via Yahoo to SonyMobile
Well, I have done several cars in white, and used grey primer, and it comes out fine, just make sure you do nice even coats of paint or it wont cover properly, but still, your better off using white primer for white paint, it just looks better, grey primer makes everything appear darker.
Old 04-09-2004, 09:48 PM
OzZySi's Avatar
Thanks bro. My problem is, I want this car to come out perfectly. I have white primer, but the best kind I can get in white doesn't spray nearly as nice as the light grey tamiya...
~OzZySi
Old 04-09-2004, 10:00 PM
supermod04's Avatar
supermod04 supermod04 is offline
Banned
Send a message via AIM to supermod04 Send a message via MSN to supermod04
Re: Pearl white over primer...
hey ozzy. well i had the problem with grey over white, just wont cover. i would go to fred meyer or somewere and buy duplicolor white primer, and before you paint, wet sand with some 1000 grit that will make the white primer smooth and let the gloss white stick. but try some duplicolor white primer
Old 04-09-2004, 10:11 PM
OzZySi's Avatar
OK, I'll opt for the white then...
~OzZySi
Old 04-09-2004, 10:17 PM
djmr2's Avatar
djmr2 djmr2 is offline
Do the pearl white over a solid white, white primer is not very nice looking to put the pearl white over, but it'll be nicer than grey primer.
but it's best if you put it over a solid white.
Old 04-09-2004, 10:22 PM
Lambo003's Avatar
Lambo003 Lambo003 is offline
I used TS27 Matt White as a base for TS45 Pearl White with good results. . . Just be sure to build up the coats in light mists
Chuck
Old 04-09-2004, 10:29 PM
supermod04's Avatar
Banned
yea the trick with white, is not to spray it heavy but to spary many light coats. i had some bad experince with it!
Old 04-09-2004, 10:34 PM
OzZySi's Avatar
Ok, so it's white primer, white base coat, then pearl white paint?
~OzZySi
Old 04-09-2004, 10:43 PM
supermod04's Avatar
Banned
well you can do that or
just white primer then white base.
or white primer, white base then pearl.
OR white primer and a white pearl base.
Old 04-09-2004, 10:48 PM
Vric's Avatar
Vric Vric is offline
Pearl white need a white base color
I used it for my Bomex Rx07, look really good, but you need an even white base coat.
it don't cover much, but you can try to mix color (like a gold base, or a silver.. lot of option
Old 04-09-2004, 10:49 PM
supermod04's Avatar
Banned
Re: Re: Pearl white over primer...
Ok so then a white primer, white base, and white pearl.
I am sorry for being wrong i did not know white pearl needed a white base. thats my fault
Old 04-09-2004, 11:44 PM
ywwong ywwong is offline
White primer, TS26 pure white then TS45 pearl white then TS13 clear coat it was how i did my pearl white 350Z
Old 04-11-2004, 12:42 PM
mel_carramel's Avatar
mel_carramel mel_carramel is offline
Send a message via MSN to mel_carramel Send a message via Yahoo to mel_carramel
i tried pearl white on my 350Z.. i cant tell the different... can someone say something bout this pic...
im new btw... very new.. this block is my 2nd built.. so im not yet even amatuer.. just a starter
Old 04-11-2004, 12:43 PM
Vric's Avatar
Re: Re: Re: Pearl white over primer...
no real need to make a white base if your white primer is smooth
Pearl white over metalic blue base? SHIFT_drift Car Modeling 7 12-18-2004 09:39 PM
Pearl White and Pure White TanKaBoY Car Modeling 8 11-04-2004 04:51 AM
Pearl White 1995 3000GT VR4 SPYDER For Sale Trans Am 3000GT/Stealth 6 09-16-2004 12:09 PM
pearl white s2000 with white interior urban1979 Car Modeling 14 07-19-2002 04:26 PM
Pearl white over metallic blue = ??? howiedoit Car Modeling 5 06-11-2002 05:28 PM
