Go Back   Automotive Forums Car Chat > Toyota > Supra > Maintenance
Maintenance Have questions? Find answers. Help out fellow Supra owners.
Old 04-09-2004, 01:14 PM
BobbyisKing BobbyisKing is offline
car wont start after bhg repair?
just finished bhg repair, almost sure that i did everything correct other than forgetting to mark the cps to the head. when i was trying to start the car, the car was trying to crank but wont start. when i stop cranking it, i hear a loud pshhhhhhhh sound and see some pressurized wind come up from somewhere on the intake manifold? also, what are the reasons why a car wouldnt start? like i said, i am almost certain that i did everyting correct. please, any tips would be helpful. thanks
Old 04-09-2004, 04:24 PM
projectsupramk3's Avatar
projectsupramk3 projectsupramk3 is offline
Send a message via AIM to projectsupramk3
Re: car wont start after bhg repair?
That can't be a good sign, nothing should be compressed or pushed out of the intake on startup lol. When you pulled the head did you touch the cams at all? How about the pistons/crank? You lined up all the cam timing marks when you put the head and new timing belt back on right? TDC compression also I hope? Heres the links again on how to set the CPS...
http://cygnusx1.net/supra/library/TSRM/ig/IG_21.html
http://cygnusx1.net/supra/library/TSRM/ig/IG_24.html
Old 04-09-2004, 04:44 PM
before i took the head off, i marked with white out the tooth of the timing belt to the cam gear and to the back cover thingy, basically a straight line. when working with the engine, i never moved the pistons or cranked, i did move the cams to allow the head bolts to be taken out, but i matched up the lines before i put it back. the only thing i didn't do was use white out on the cps before i unbolted it.
Old 04-09-2004, 04:47 PM
basically, the engine was put on exactly when it was taken off, other than the cps not being exact.
85 cutlass wont start after gasket repair Escalus Cutlass Series 2 03-23-2006 06:47 PM
Car wont start after car wash today nazznomad Cutlass Series 2 11-16-2005 01:45 PM
Car wont start after shut off a while. Justinh722 Grand AM 0 12-15-2004 03:50 AM
car wont start after headgasket replacement audioquattro '88 - '91 Civic | CRX | Wagon | Shuttlee 4 06-14-2004 03:02 PM
Help, car wont start after a minor accident. AznBlood '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 11-17-2003 11:24 AM
