Old 04-03-2004, 03:59 PM
bobbruce04 bobbruce04 is offline
change oil light
does anyone know how to turn off the change oil light? mine wouldn't go off after the last oil change.
Old 04-03-2004, 08:55 PM
AznGA AznGA is offline
Re: change oil light
You have to reset it after every oil change. If you open the driver side fuse box, you will see the red rectagular reset button. Turn your ignition on, either hold it or press that button. The change oil light will blink. Press or hold it again. Something like that. Check your manual.
Old 05-20-2004, 02:38 AM
junior59 junior59 is offline
If there isn't a red reset switch in the panel, or even if there is, you can reset it using the gas pedal.
Turn the key to the on position which is when all the lights and dings start going on. When the change oil light is on, press the gas pedal down 3 times within a 5 second period. the light will flash a few times then go off. You cna then turn the key back to off and then restart it and the light should be off after that.
When you reset it using the red button in the panel, Turn the key to the on position, hold the button in until until the light flashes and sometimes you will hear a series of beeps. that will signify that it is reset.
Change Oil Light and Low Water Light bblokey Intrigue 3 09-02-2005 05:21 PM
Olds 2001 Intrigue Change Oil light jander411 Intrigue 3 04-28-2004 12:31 PM
Change Oil Light krist1n Grand AM 1 12-07-2003 06:16 AM
Change Oil Light continues after change Gone Fishing C/K 8 10-28-2003 04:31 PM
Change Oil Light gonetobama13 C/K 5 08-24-2003 12:00 PM
