Old 01-22-2005, 04:54 PM
bblokey bblokey is offline
Change Oil Light and Low Water Light
How can I reset my change oil indicator after getting an oil change?
And what can cause the Low Water Indicator to come on and off even when the water level is okay and it ain't over heating???
Please Help....
Old 01-22-2005, 06:15 PM
Burnout524 Burnout524 is offline
Re: Change Oil Light and Low Water Light
To reset the Change Oil Indicator, turn the key to the on position without starting the engine. Then press the gas pedal to the floor three times within five seconds. The light should blink and then you're all set.
As far as the water light problem, I'm not sure what to tell you. Go to an auto parts store and get the diagnostic codes. My guess is that its a bad sensor.
'99 Olds Intrigue GX
Old 01-23-2005, 02:03 PM
Re: Re: Change Oil Light and Low Water Light
Thanks
Old 09-02-2005, 05:21 PM
jy447 jy447 is offline
to reset the change oil light:
- turn key to on position with out starting it
-press the gas pedel to the floor 3 times. (the change oil light should flash )
-turn key to off then start,it shoud be reset.
