Old 03-07-2003, 09:46 AM
Gone Fishing Gone Fishing is offline
Question Change Oil Light continues after change
Does anyone have a clue as to how to reset or turn off the Change oil Light? I just hit 3500 miles and changed the oil last week, but it still flashes on start-up and remains on. I have checked the oil level just to be safe and it reads full (I do not think it is over full).
I called the local dealer, who said that it should go off in a day or two if everythings OK. But he was quick to tell me to make an service appointment for next week (better to get on the calendar now).
Anyone else have a flakey Oil Light? Thank for your ideas!
Old 03-07-2003, 09:51 AM
Shortbus Shortbus is offline
Blah blah blah
Send a message via AIM to Shortbus
Welcome to AF.
GM Oil Life System - Resetting
The engine oil life monitor will indicate when to change the engine oil - usually between 5,000 km (3,000 miles) and 16,000 km (10,000 miles) since the last oil change. Under severe conditions, the CHANGE OIL SOON light may be displayed before 5,000 km (3,000 miles). The vehicle must not be driven more than 16,000 km (10,000 miles) or 12 months without an oil change.
The engine oil life monitor will not detect dust in the oil. If the vehicle is driven in a dusty area, be sure to change the oil every 5,000 km (3,000 miles) or sooner if the CHANGE OIL SOON light is displayed.
Reset the oil life monitor when the oil has been changed, use the following procedure.
Turn the ignition key to the RUN position.
Fully push and release the accelerator pedal 3 times within 5 seconds.
If the Chane Oil Soon light flashes, the system is resetting.
Start the vehicle.
The oil life will change to 100%.
If the Change Oil Soon light comes back on, the system has not reset. Repeat the procedure.
Old 03-07-2003, 09:53 AM
Blah blah blah
Forgot to add that the oil life monitors do not reset themselves.
Old 03-07-2003, 11:00 AM
Thanks
Ammazing what you can learn by "Reading The Funny Manual."
Also thanks to John. Why is it that noone at Jiffy Lube knows that?
More importantly, you would think that the Chevy Dealer and Service Manager would know that!
Thanks again!
Old 03-07-2003, 11:39 AM
Blah blah blah
Yeah I was going to say that the info should have be in your owners manual, but thought it would be just as easy to post it here for others to see as well.
I would think your local GM dealer would have known this also.LOL
Oh well thanks for the update
Old 03-08-2003, 11:45 PM
DMC12's Avatar
DMC12 DMC12 is offline
DeLorean Guy
Re: Thanks
Sadly you've hit the bullseye with these two statements. Nobody knows nothin'!
I stopped using Jiffy Lube after they over-filled my last car's engine (blowing all seals - "not their fault").
As for dealerships, well... reading my threads will enlighten you on where the "Like a Rock" statement comes from
SOLID! crew (circa 2002).
DeLorean moderator.
Old 10-08-2003, 08:33 PM
needn_help needn_help is offline
Thumbs up Re: Re: Thanks
John thank you so much for putting those instructions. My used Grand AM GT did not come with an owners manual.... The light has been on for the last three oil changes. The first oil change the oil changer at Wal-Mart reset it but after that no one knew how to do it.....
Old 10-09-2003, 06:37 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: Re: Re: Thanks
If you open the drivers door and look at the side of the dash, you will see the fuse box cover. Remove the cover and you will see a red reset button. Turn the ignition key to ON (engine not running) and press the button once, you will see the oil change light flash, press and hold the button untill the light flashes and you hear a beep....Now the syatem is reset.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 10-28-2003, 04:31 PM
eriojas eriojas is offline
does the procedure for the suburban is for the new or old models?
200-2004, 1995-1999, etc
Oil Pressure 130 Pounds Smith1000 Park Avenue 10 04-18-2011 08:39 PM
