Old 03-31-2004, 01:46 PM
99Zseven 99Zseven is offline
parking light out, but turn signal works...
My front left parking light is out but when I put my turn signal on, the turn signal works. I have changed the bulb and the parking light still doesn't work. Does anyone know what the problem might be??
Old 03-31-2004, 04:29 PM
Gooseneck Gooseneck is offline
Re: parking light out, but turn signal works...
Are your other park lights working? If not, check for a blown fuse. The park and signals are two separate circuits although they use the same bulb. Your signal and park light are the same bulb or bulbs but they are duel element. Since you have replaced the bulb, that pretty much eliminates that, if you replaced it with the correct duel element bulb. If you have a voltmeter or a test light you can check for voltage in the light socket. One pole is for signal and one is for park light, the ground is common for both elements. If just this one park light is not working it is probably a problem with the bulb socket or assembly or the wiring in the close vicinity of the light. Make sure socket is free of corrosion.
Old 03-31-2004, 06:41 PM
thanks.
turn signal lights not working x3mtm Durango 4 01-11-2010 12:49 PM
head lights out!! but parking light still on!! mad57 Caprice 6 11-07-2006 07:23 PM
2000 Durango -- Brake lights work, Turn signals work -- Running lights don't??? bonomarine Durango 2 03-20-2006 10:41 AM
No lights out, but the fast turning signal noise? rockfan0005 Grand AM 3 11-25-2005 03:52 PM
Brake light, airbag light stay on, turn signals won't work intermittent Moreen Windstar 1 07-14-2004 01:17 PM
