Old 03-31-2004, 12:35 PM
evh1984 evh1984 is offline
'89 High Idle Speed
My '89 is idling too fast! I have replaced the IAC valve, cleaned out the port in the throttle body for the IAC, re-check the dimension on the pintle (1-1/8"), check the linkage. Does anybody have any suggestions?
Old 04-01-2004, 03:15 AM
amac209 amac209 is offline
Send a message via MSN to amac209
Re: '89 High Idle Speed
did you unhook the battery to reset the computer??also check the throttle body base gasket for a vacuum leak
Old 04-01-2004, 07:58 AM
Tried the battery, it turned out to be a leaky throttle body gasket. Thanks!
'89 High idle when warmed up........ davemc53 Dakota 4 09-09-2005 12:18 AM
high idle speed Angel Martinez Sable 0 01-18-2005 06:49 PM
High Idle Speed/rpms..help new2bmw 3 Series 2 03-18-2004 12:49 PM
I can't figure out my high idle speed?!?!? jmslms Jetta/Vento/Bora 1 03-08-2004 04:50 PM
High Idle Speed ricecube77 Maintenance 5 10-07-2001 07:37 PM
