Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Maintenance
Maintenance problems, fixes.
Old 10-07-2001, 04:02 AM
ricecube77 ricecube77 is offline
Send a message via AIM to ricecube77
High Idle Speed
About 2 months ago, i got a new AAC Valve (at 60000 miles)... my old one kept stalling when i came to a light.
Currently, when my car's in neutral i seem to have an unusually high idle speed. Well, now i have time to deal with it so..
My idle speed in neutral is 1100 RPM's... where i hear the usual idle speed is around 800 RPM.
Not to mention, im getting ONLY around low 20 MPG for my fuel economy. Does a high idle speed cause low fuel milage?
***How can i LOWER my idle speed a bit?***
-Phil
94' Silver P10 G20
Old 10-07-2001, 05:05 AM
greekman's Avatar
greekman greekman is offline
Re: High Idle Speed
you can adjust the throttle cable, but that's probably not your problem. check out www.se-r.net and in the common problem/fixes section you might be able to find some answers and fixes for your problems
your poor mpg may be due to a bad O2 sensor. have you ever replaced it? how many miles do you have?
93.5 G20
Life is like a shit sandwich. The more bread you have, the less shit you taste. So go out and get your bread!
Old 10-07-2001, 01:02 PM
It doesn't say anything about lowering idle speed. I check the SE-R forum before i post
ABout the O2 sensor, im not sure really. Currently the car has about 70300 miles on it. ... Where is the o2 sensor?
-Phil
Old 10-07-2001, 06:34 PM
greekman's Avatar
did you check out http://www.se-r.net/engine/adjust_idle.html or http://www.se-r.net/car_info/problem...jumping%20idle
either of these might be able to help, assuming you didn't see these when you checked out se-r.net before posting.
93.5 G20
Old 10-07-2001, 06:36 PM
greekman's Avatar
i just realized that i've posted 100 times. i remember when i was just a newbie.
93.5 G20
Old 10-07-2001, 07:37 PM
G20-KIWI G20-KIWI is offline
Have you checked that the TPS is adjusted correctly?
Also the idle speed may have been adjusted to compensate for a low idle as the AAC
valve was dying. On the RH side of the engine at the back(behind the inlet manifold)
there is a screw to adjust the idle if you dont know what you are doing dont try to change it.
-=G20-KIWI=-
High idle speed trigger_y2000 Monte Carlo 3 04-09-2005 03:47 PM
high idle speed Angel Martinez Sable 0 01-18-2005 06:49 PM
'89 High Idle Speed evh1984 C/K 2 04-01-2004 07:58 AM
High Idle Speed/rpms..help new2bmw 3 Series 2 03-18-2004 12:49 PM
I can't figure out my high idle speed?!?!? jmslms Jetta/Vento/Bora 1 03-08-2004 04:50 PM
