Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 08-22-2005, 11:09 AM
davemc53 davemc53 is offline
'89 High idle when warmed up........
Once my truck ('89 3.9 4WD) gets warmed up, it idles pretty fast. It's OK when just started. I turned the adjuster nut that is on the accelerator cable as far down as it will go. Helped a little, but not near enough. I'm sure it is nothing to do with the pedal, because I can "kicK" the pedal and it still idles fast.
It also starts hard when it is hot.
Any suggestions as to what it might be?
Old 08-24-2005, 03:28 PM
No ideas?
No ideas I guess, huh? Was it that stupid of a question, or too complicated? Just looking for some guesses as to what it might be.
Thanks,
Dave
Old 08-28-2005, 01:30 AM
stanbell stanbell is offline
Re: '89 High idle when warmed up........
Could be you idle speed control motor located beside the carb.
Old 09-05-2005, 08:06 PM
Gizmokid2005 Gizmokid2005 is offline
Send a message via AIM to Gizmokid2005 Send a message via MSN to Gizmokid2005 Send a message via Yahoo to Gizmokid2005
Check your Idle Speed Control Motor and your Throttle Position Sensor
Old 09-09-2005, 12:18 AM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
also check for a vacuum leak.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
