Old 03-29-2004, 03:18 PM
thre3kgt811 thre3kgt811 is offline
need help w/ stock cassette/radio
i was jus wondering if anyone knew how to easily take out the stock cassette player and radio out of a 91 sl
also i noticed in the manual the clutch fluid reservoir is shown right next to the battery on the left and in my car its all the way on the right..why is this????
and is the clutch fluid also used for the gears? its a manual...thanks
Old 03-30-2004, 02:03 PM
93SL_FL 93SL_FL is offline
Send a message via AIM to 93SL_FL
First, it's very easy to take out the stock radio player. Take a screwdriver and pry the outer cover around the sterio off. Next there should be 4 philips head screws holding it in place. Take them out, pull out a few wires from the back of it and you're done. Go on www.stealth316.com for pictures, and for any questions you might have. Now, the clutch fluid is for all manual transmissions. Automatic transmissions don't have clutch fluid because they don't have a clutch. Listen, if you really have a 3/S, you should consider selling it because someone out there is looking for one that really knows everything, OR if you really appreciate your car then forget what I said about selling it. Good luck. Im out.
F-250 radio problems...Need help farmboy401 F Series 0 05-10-2010 07:10 PM
Need help removing factory radio in 99 ex. cab. digital_darkness Silverado 7 10-04-2005 08:21 PM
need help with a radio code please snowball1288 Interior | Audio | Security 3 04-21-2005 04:28 PM
1994 325i need help putting in radio code !!! thejushinator 3 Series 5 11-09-2004 12:59 PM
need help!!!!! stock 91 Si rear speakers??? rsoares28 '88 - '91 Civic | CRX | Wagon | Shuttlee 8 08-27-2002 10:48 PM
