Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Maintenance
Maintenance problems, fixes.
Old 03-27-2004, 11:18 PM
rfb6435 rfb6435 is offline
shifter clicking after brake pad change
Hopefully someone can give me some advise on this.
I am not sure if I broke something or if I need to adjust something.
I changed the front brake pads on my GF's p11 G20. I re-compressed the calipers with a c-clamp without opening the bleader valve.
Now there is a click in the shifter area when the car is in park and the brake petal is pressed. Other than that the brakes seem fine.
She is annoyed with it so I need to resolve the problem!
Thanks in advance,
Rich
Old 04-22-2004, 01:39 PM
JalopyGuido JalopyGuido is offline
Send a message via MSN to JalopyGuido
Re: shifter clicking after brake pad change
It has done that all along. It is the electronic switch that releases the shift lock so that you can move the shifter from park...they usually all click like that. Thanks
Old 08-14-2005, 06:51 PM
J..M's Avatar
J..M J..M is offline
Get a New GF
Problem solved
Front end vibe after brake pad/rotor replace geschaef Camry/Camry Hybrid/Vista 4 05-24-2010 02:24 PM
brake pad changing trouble annarborhawk '97+ 2 12-31-2005 11:04 AM
Should I get my Brake Pads changed?? Dpdblues Taurus | Taurus Wagon 2 03-12-2005 10:33 PM
