Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 04-30-2010, 04:49 PM
geschaef geschaef is offline
Front end vibe after brake pad/rotor replace
Just replaced pads and rotors on the 96 Camry 2.2. Town driving and stopping, no noticeable pulsing when I depress brakes. But when I brake at highway speed to a stop, that higher speed braking produces vibes in the front. Are the new rotors warped? Caliper or piston the culprit? Thanks for helping me solve.
Old 04-30-2010, 07:15 PM
Mike Gerber Mike Gerber is offline
AF -Advisor
Re: Front end vibe after brake pad/rotor replace
"Are the new rotors warped?"
It's possible. Did you clean off all the rust on the hub before installing the new rotors? I have seen rotors that weren't seated evenly because of rust on the hubs. Check that first.
Mike
Old 05-01-2010, 01:24 PM
quick69gto quick69gto is offline
Not torquing the lug nuts to spec will cause the rotors to warp also.
Old 05-06-2010, 09:26 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Check your tie rod ends and ball joints for wear as well. Shaking/vibration during high-speed braking can be caused by sloppiness in the steering and suspension.
Also don't forget to clean and reajust the rear brakes so that they are contributing as well. Front brakes that do all the work will eventually warp. You should be able to feel the rear brakes engage slightly before the fronts when braking lightly. Good luck!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 05-24-2010, 01:24 PM
Thanks for all the helpful posts. Cleaning off the hub rust reduced the vibe. Checking the front suspension is needed on this vehicle...that's next.
Now if I can just get rid of that brake squeal. Applied lots of quiet lube on pad back.
