Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 03-21-2004, 05:03 AM
Gideon5 Gideon5 is offline
Send a message via AIM to Gideon5 Send a message via Yahoo to Gideon5
would a 1.75 need a new camber kit?
I read an earlier thread, and this guy said that on 1.75 it needs a new camber kit, is that lower than 1.75, or 1.75 and lower?
Old 03-21-2004, 01:55 PM
BullShifter's Avatar
Re: would a 1.75 need a new camber kit?
It depends on the year/make/model some cars have camber adjustment while others don't. Most factory adjustments can not adjust as much as needed so aftermarket camber kits are needed. If the car does not have camber adjustments(civics) camber kits are needed for any drop to get proper alignment, but tire wear/handling aren't really affected until 1.5-1.75" or more drop. Best way to tell is on an alignment machine & watching tire wear.
Old 03-21-2004, 02:01 PM
PhiberOptik's Avatar
PhiberOptik PhiberOptik is offline
I am taking my car in on Wednesday to check my specs, if I find my offset or my camber is off and I need to purchase a camber kit I noticed some people only buy the front camber kit where as some people only buy the rear. Why is this? Also if the offset is off is there an offset kit I can purchase to correct it? thanks
99 Civic EX
Si Spoiler
Type R mesh grill
Old 03-21-2004, 02:29 PM
Re: Re: would a 1.75 need a new camber kit?
With sportlines & 17's you will need front & rear kits. The rear's can be adjusted slightly, not correctly, but it works. All you need is longer bolts & some washers, there's a link around here some where for how-to, search for washer trick. I recommend kits over the bolt/washer trick, if you do use the washers make sure to use HIGH GRADE BOLTS not some $0.10 piece of shit from the hardware store.
To fix offset the best way is new wheels or the option of wheel spacers depending which way it's off & wheel size/tire size.
Old 03-21-2004, 02:35 PM
OK, I called around some local stores and they want about $200-300 for a front and rear camber kit, should I shell that out or buy online? What exactly comes in the kit besides new bolts?
99 Civic EX
Si Spoiler
Type R mesh grill
Old 03-21-2004, 03:13 PM
I checked out http://www.modacar.com/products/Honda/Civic/MODACAK/
and found some on there but they are the same price if not more expensive, if anyone knows of a cheaper site please inform
99 Civic EX
Si Spoiler
Type R mesh grill
do I need a camber kit? omnicrap Wheels/Tires/Suspension 2 02-10-2005 04:34 AM
do i need a new camber kit? SiRacer Wheels/Tires/Suspension 7 01-29-2005 07:48 PM
Will I need a camber kit and recommended springs? gsr456 Integra 5 01-10-2003 06:06 PM
got a alignment...do I need a camber kit? j32pilot '88 - '91 Civic | CRX | Wagon | Shuttlee 7 05-04-2002 08:43 AM
