Go Back   Automotive Forums Car Chat > Honda > Wheels/Tires/Suspension
Wheels/Tires/Suspension All the handling help you need. No matter what Honda/Acura you drive.
Old 01-18-2005, 05:56 PM
SiRacer SiRacer is offline
do i need a new camber kit?
i was planning on buying tokico springs shocks and struts in a kit for my 2000 civic si. the kit will drop the car 1.5 inches and i have 17s on it. but before i buy, i was wondering if i need to buy a new camber kit or whatever i need so i dont have any problems.. if anyone could help that would be great. thanks
Old 01-18-2005, 07:48 PM
honda4u honda4u is offline
Send a message via AIM to honda4u
Re: do i need a new camber kit?
ya i think so because i lowered my crx and i had to put new cambers on it, but im not 100% sure.
89 yellow crx
b16 swap
Old 01-18-2005, 08:03 PM
CivicSiRacer's Avatar
CivicSiRacer CivicSiRacer is offline
Civic Mod
Send a message via ICQ to CivicSiRacer Send a message via AIM to CivicSiRacer
Anything less than a 2" drop you really don't need a camber kit. You just want to make sure you get an alignment soon after you drop your car since toe also changes which can wear your tires pretty fast.
Sponsored by: KAM Racing Sports, Falken Tires, Finish First Polish, Brady's High Performance, Taggart Performance Engineering, Rotora Brakes
Autocross is: 90% driver, 5% car, & 5% CRAZY MOJO!
Autocross Help Page
Buy my Civic parts!
Old 01-18-2005, 08:18 PM
ok thanks. so the alignment just needs to be adjusted when i drop it and ill be fine? what are some other things i should watch out for?
Old 01-19-2005, 03:23 PM
Civic Mod
You should watch out for speed bumps, steep driveways, and potholes. Also you may have problems getting your car on lifts unless you bring 2x4s with you.
Autocross Help Page
Buy my Civic parts!
Old 01-19-2005, 04:17 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Re: Re: do i need a new camber kit?
Yes good advise always keep some 2x4's or something similar so that if you have a flat tire etc you can get the jack under your car.
Old 01-29-2005, 06:35 PM
MrCrazy's Avatar
MrCrazy MrCrazy is offline
so your saying that anything lower than a 2 inch drop i wont need a camber kit????
Old 01-29-2005, 06:48 PM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
No you won't. It's going to obviously give you little negative camber, but more than likely not anything outside of factory specs.
Empty Pockets Racing Member #1
