Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 03-21-2004, 12:07 AM
skuri skuri is offline
85 Caprice won't shift out of 1st
I just did a tranny filter service on my 85 caprice, 305 with OD tranny. After the service, which was just filter and fluid, it wont shift out of 1st gear until about 25-30 MPH, and shifts hard. What could this be???
Old 03-30-2004, 03:56 AM
amac209 amac209 is offline
Send a message via MSN to amac209
Re: 85 Caprice won't shift out of 1st
most likely low fluid level. check the level idling in park after driving a few miles.
Old 03-30-2004, 10:23 PM
ridge_runner ridge_runner is offline
Send a message via AIM to ridge_runner Send a message via MSN to ridge_runner
if its not that check your kickdown cable on your carb
Old 04-11-2004, 03:37 PM
dxrflyboy dxrflyboy is offline
Make sure you didn't bend or jam the throttle valve mechanism. The easiest way to check it is at the carb. The cable should be retracted as far as possible. If you pull on it, there should be spring tension and it should pull back when you release it. Otherwise, the mechanism is probably jammed in some way, most likely at the valve body, since you just had the pan off. If you're lucky, the link between the cable and bellcrank snagged inside the cable housing and can be fixed without dropping the pan.
Please Help, '99 AT Mitsu Eclipse won't shift into 3rd '99EclipseProblems Engine, Transmission and Drivetrain 6 09-13-2009 10:03 PM
99 Durango won't shift out of 1st gear urfavejerzeygrl Durango 2 07-11-2007 09:02 PM
97 Trans Sport idling rough,won't shift out of 1st punkrockgirl68 Trans Sport 1 01-24-2007 09:05 PM
95 oldsmobile cutlass supreme won't shift out of 1st gear Solanacae Cutlass Series 2 02-19-2005 12:12 PM
