Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 02-13-2009, 06:32 PM
'99EclipseProblems '99EclipseProblems is offline
Please Help, '99 AT Mitsu Eclipse won't shift into 3rd
Hi guys,
I could really use some help, I'm not very automotive savvy and am completely at wits end at the moment. My '99 Mitsubishi Eclipse does not want to shift into 3rd. I'll drive down the road and all the sudden it will not want to shift up into 3rd and drives at 5000 rpms at 45 mph or so.
I took it to a transmission shop here in Ft. Wayne and the guy said the diagnostics said that there was no issue with the transmission and that it should be fine, thought that maybe it would be electrical....
Just bought 1st house so I can't afford really to take it to the dealer, does anyone have any advice as to what's wrong? Had this issue with a similar car?
Just not sure what to do right now... Thanks in advance guys.
Old 02-13-2009, 07:11 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: Please Help, '99 AT Mitsu Eclipse won't shift into 3rd
It could be a few different things. First off, I would start with the cheapest fix to see if it takes care of the problem your having. Considering it's a 10 year old car, it probably has higher mileage on it. First thing you should try doing is changing the transmission fluid and filter. Sometimes that is the culprit to this type of problem. If that doesn't fix the problem then it very well could be an electrical problem. The next step would be to have the TCU (transmission control unit) checked to see if it's going out on you. If it is diagnosed and reads fine then it could be something as major as the transmission going bad. Although I wouldn't worry too much about it. It's more than likely just needing the fluid and filter changed in it. Good luck and let us know the results.
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 02-13-2009, 10:12 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Will it slip out of the higher gear into the lower gear, or will it just not shift into the higher gear period? What about the lower gears, will it shift from 1st to 2nd without any trouble?
I do have to say though, I'd change the fluid just to see if it helps, like Blackcrow said. Beyond that, it almost sounds like what the work truck did at work to me two summers ago... and if thats so, then kiss your tranny good bye.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 02-14-2009, 07:10 AM
Thanks for the input guys, I'll start with that. It doesn't seem to have problems going from 1st to 2nd and back down to 1st, it just doesn't want to get up into 3rd. Also going from drive to neutral at times will result in a loud clunk and a hard shift.
It also doesn't do it all of the time. For instance, this morning and yesterday afternoon I drove it 10 to 15 miles and it didn't have any problems shifting up into 3rd 4th, drove great and while driving the service engine soon light went off.
It has kind of came and went the last two days or so.
Like I said, Summit City transmission said that based on diagnostics, it wasn't a tranny issue but was electrical. For whatever that's worth.
Thanks for all the help, this forum is fantastic.
Old 06-07-2009, 10:18 PM
Prime First's Avatar
Prime First Prime First is offline
Send a message via AIM to Prime First
It won't shift into 3rd because the transmission is designed to protect itself if anything is wrong with it. A number of things can send the transmission into "limp mode." At this point, the transmission won't shift as a precaution.
Prime First
1999 Mitsubishi Eclipse
10th Anniversary Edition
Old 09-13-2009, 08:51 PM
ClearwaterEclipse ClearwaterEclipse is offline
I just experienced the exact same problem with my 1998 Eclipse...It worked fine until I made a u-turn and started driving. It went to like 3500 rpm, and didn't shift into 3rd. I don't know what to do. It is continuously doing it, and it just happened tonight. I made a few stops and turned the car off, but the problem continued! Please help me out!! Please! Thanks
Old 09-13-2009, 10:03 PM
ned032002's Avatar
ned032002 ned032002 is offline
I once had a problem like this and it turned out to be the Throttle valve cable (TV Cable) broke free from the throttle plate and that just about ruined my tranny. Wish I were more helpful but keep us updated.
Tags
'99 eclipse , eclipse transmission , won't shift into 3rd
