Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 03-20-2004, 09:14 PM
robbie1339 robbie1339 is offline
maxima will not idle
i have a 1987 maxima which has been driving perfectly since i purchased several years ago as well the earlier the day it stopped. after driving the maxima around town running perfectly i attempted to start it up for a trip and it would not idle. it will start, but then stumbles off. at times i can push gas pedal to keep it running a little longer, but eventually cuts-off. i have checked all connections i can imagin to check. wondering if it could be bad gas as i did fill it up the night before the problem then drive it approx. 8 miles then the problem occured. any ideas would be greatly appreaciated. just seems as gas is not passing to the engine or it is out of gas. the lines and filter are okay.
Old 03-20-2004, 10:17 PM
thrasher thrasher is offline
Re: maxima will not idle
Well, you said you already checked the fuel lines, so I would say it could be the fuel pimp, my Taurus back in the day had the same problem.
"Don't have sex man. It leads to kissing and pretty soon you have to start talking to them."
Steve Martin.
Old 03-21-2004, 11:42 AM
ogparjay ogparjay is offline
thrasher is right ... it's the fuel pump that needs to be change....
Old 03-21-2004, 12:20 PM
i assumed the pump was working because when i turn the ignition key to ACC. i hear the fuel pump turn-on. does this not actually mean the pump is in working order? is there a way to check the pump before replacement?
thank you for the responses.
Old 03-21-2004, 12:42 PM
The pump is working if you're able to drive it, just not working correctly.
Steve Martin.
1992 Maxima will not start! madmonk210 Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 1 03-15-2006 12:30 AM
91 maxima will not run rrruschman Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 11 03-09-2006 04:38 PM
84 Maxima Will Not Start Fom The Ignition hambone35 Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 3 12-02-2005 01:49 PM
My 95 Maxima will not start, help!!!!!!!!!!!! Mailt4 Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 3 04-28-2005 02:55 AM
integra will not idle Rover 2 Integra 3 12-13-2003 12:49 AM
