Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 04-23-2005, 02:52 PM
Mailt4 Mailt4 is offline
Question My 95 Maxima will not start, help!!!!!!!!!!!!
Hi All,
1995 Maxima won't start, cranks good, fuel pressure at 34psi, fuel pump is runing, no Code, just replace Crank Sensor (REF), Ignition Condenser, check Voltage at POS crank sensor ok, any help ???????
Mai
Old 04-26-2005, 12:51 PM
Nahkapohjola's Avatar
Nahkapohjola Nahkapohjola is offline
Re: My 95 Maxima will not start, help!!!!!!!!!!!!
Originally Posted by Mailt4
Hi All,
Mai
- take one coilpack off, insert spare plug, ground it. Start, view for spark?
- Rotate crank sensor while ign on. Hear injectors click?
If both of those are good, fuel is still not reaching your injectors...
Maxima INFO pages was deliberately trashed (!?) by Cardomain; dont goto http://www.cardomain.com/ride/748507
There was a special Car Electronics -page http://www.cardomain.com/ride/748507/14
Old 04-27-2005, 06:32 PM
I checked it all, Fuel is at the Combustion Chamber, Spark is good (check with a Spark Plug tester) Crank signal is there (REF and POS) Cam Sensor is good,
After these long Tests I got Pissed and put averything back and Crank the crap out of it and the Engine started to run about 200rpm then 300rpm and after 3-5minutes or so it got up to 600-700rpm, it sound like 2 or cyl is running, runs smooth but weak,
Now I put the Scaner on and I've got a KNOCK SENSOR code, Knock Sensor ??????? does not make any sence,
I cleared the code, took it out for a ride, again runs smooth buy weak and when you rev and back off, rpm drop so low that you feel like it going to stall.
Came back, no CEL, ran the Scaner,still get Knock Sensor code.
This is all for today, I'll keep you all posted!!!!!!!!!
Old 04-28-2005, 02:55 AM
Re: Re: My 95 Maxima will not start, help!!!!!!!!!!!!
...after 3-5minutes or so it got up to 600-700rpm, it sound like 2 or cyl is running, runs smooth but weak,
Now I put the Scaner on and I've got a KNOCK SENSOR code, Knock Sensor ?....
- Throttle Position Sensor works on cold engine. After warmup =5min, its no longer used, O2 will be used instead. ---> Clean or replace TPS
clic: http://www.cardomain.com/memberpage/748507/6
- Try knock sensor bypass:
clic: http://www.cardomain.com/memberpage/748507/9
