Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 03-14-2006, 09:02 PM
madmonk210 madmonk210 is offline
1992 Maxima will not start!
My girlfriend met me at the gas station one day and turned her car off. would not start after that. Unless gas held to floor, then it would run only florred and would only get to 3000 rpm.If I let off it would die. Can someone help me diagnose this problem or maybe a tip.
Thank you, Madmonk210
Miles
Old 03-15-2006, 01:30 AM
Nahkapohjola's Avatar
Nahkapohjola Nahkapohjola is offline
Re: 1992 Maxima will not start!
Originally Posted by madmonk210
...Unless gas held to floor, then it would run only florred ...
No info of mileage, engine type. Start from tuneup: plugs, filters, VGE: replace wires, cap
If no Idle, points to Idle adj circuit. Check air input & vacuum hoses. Cleanup after every 60-100k helps; the cause for sudden change could be IACV jam. IACV cleanup for VGE engine below; (VE is located differently.)
Low rpm: Check MAF, TPS & CamPos sensor outputs. See link pages 9,10,12,14 below.
Check Fuel pressure.
Maxima INFO pages was deliberately trashed (!?) by Cardomain; dont goto http://www.cardomain.com/ride/748507
There was a special Car Electronics -page http://www.cardomain.com/ride/748507/14
