Old 03-17-2004, 06:46 PM
dsnynut dsnynut is offline
Send a message via Yahoo to dsnynut
Keyless programming for a 2000 Chevy Silverado
Hi, can anyone help me with programming a keyless remote on a 2000 Chevy Silverado. Any assistance will be appreciated.
Thanks,
Lisa
Old 03-18-2004, 01:36 PM
BRARUN BRARUN is offline
Re: Keyless programming for a 2000 Chevy Silverado
hold lock and unlock buttons at same time for 1 to five mins while sitting in truck and every thing off also you can take the remote apart like you would changing battery and it sould say how to on inside of the bottom half of remote case
Old 03-18-2004, 06:51 PM
kdolson kdolson is offline
Re: Re: Keyless programming for a 2000 Chevy Silverado
1.start with the ignition off door close,hold down the power unlock button on the door panel,turn ignition key on,off,on,off.release power unlock button on the door panel .the locks will cycle once.2.hold down the key fob lock and unlock buttons for about 30 seconds.the locks will again cycle once.repeat step 2 for additional key fob turn ignition to exit programming mode
kdolson
Old 04-11-2004, 02:06 PM
greensilver greensilver is offline
Keyless remote not working on my 2001 Silverado
I have a 2001 Silverado and neither of my fobs work (replaced both with fresh batteries) I tried resetting the fobs by holding Lock and Unlock on the fob for 7 seconds, as stated in my manual. No response from my truck.
I just tried kdoldon's technique. I was able to get the door locks to cycle by getting inside, holding the unlock button on the door while turning ignition on-off-on-off. But when I tried to hold the fob's Lock and Unlock for a full 5 minutes, nothing happened. I tried this with both fobs. no luck.
I'm thinking I may have a problem with the remote entry's receiver? Does anyone know where this is located and how I might check this?
Thanks alot,
Rich. (greensilver)
Old 04-11-2004, 10:42 PM
buttnekked buttnekked is offline
kdolson is correct this method worked for my 99. Took about 15 seconds for the remote to take.
Old 04-16-2004, 10:47 AM
Re: Keyless remote not working on my 2001 Silverado
Thanks alot,
Rich. (greensilver)
RICH THE RECEIVER IS LOCATED UNDER DASH ABOVE STERRING WHEEL YOU HAVE TO TAKE TOP OF DASH OFF TO GET TO IT,ARE THESE THE FOB'S THAT CAME WITH TRUCK IF NOT GO TO GM PARTS DEPT. AND GAVE THEM YOUR VIN NUMBER AND THEY WILL GAVE YOU THE PART NUMBER OF THE FOB,MAKE SURE IT MATCHS THE FOB PART NUMBER BEFORE REPLACING THE RECEIVER I HAVE NEVER SEE I RECEIVER GO BAD IT'S MORE LIKELY YOU HAVE WRONG FOBS
KDOLSON
Old 04-16-2004, 01:06 PM
If these are correct fob's I would try to find a cheap replacement on ebay before I tackled getting to the receiver.
Old 04-18-2004, 03:38 PM
Re: Re: Keyless remote not working on my 2001 Silverado
KDOLSON
Thanks Kdolson. Both fobs came with the truck. Both worked great for 2 years. 6 months ago, I started to notice the reception distance lesson; I installed new batteries (both fobs), have been playing around with reprogramming for months now. Yours was the first suggestion that gave me more than the paragraph in the manual did. Still no luck.
Unless you have any other suggestions, I will probably just have to bend over and take it to the dealer (ouch!).
Thanks again,
Rich.
Old 04-19-2004, 03:38 PM
Re: Re: Re: Keyless remote not working on my 2001 Silverado
Rich Buy A New Are Used Fob And Try It Before Taking To Dealer Buy A New Or Used Fob
.you Said It Will Go Into Program Mode So That Means The Receiver Is Working The Fobs Do Go Bad.
Kdolson
Old 04-21-2004, 12:48 PM
Thefulminator Thefulminator is offline
Be sure to hold the fobs close to the dash while holding the buttons down. If it doesn't work move to the other side of the steering wheel and try again.
Old 04-29-2004, 04:18 PM
bcrist bcrist is offline
remote entry
My 2000 Silverado was having the same problem. The security light did not come on and fobs would not unlock or lock. I tried kdolson's method and now the security light works but the fob is not. I changed the battery and still nothing. This all began after a hand car wash and detail. I noticed below the dash under the steering column a switch hanging down. It has a long metal rod that can be turned or pushed. What is this? Also if the fob is bad, where can I buy another?
Thanks!
Old 05-02-2004, 04:40 PM
Iceman31 Iceman31 is offline
Thanks this worked great on my 1999 GMC Sierra.
Keyless programming for 2000 Impala? teamfatchance General Discussion 3 09-06-2010 12:44 PM
2000 Chevy Silverado 4x4 tranny issue nymike Silverado 3 03-05-2010 09:31 PM
Hard Start...Lifters knockin after start-up for like 2 min. 2000 Chevy Silverado 5.3L Silverado_Dude Silverado 8 08-21-2009 08:28 PM
Programing keyless remote for 2005 Chevy Silverado swatglock Silverado 0 07-31-2005 04:49 PM
reprograming keyless entry for a 2000 chevy silverado 4wd mperkins20 C/K 2 07-21-2004 11:11 PM
