Old 03-05-2010, 12:34 PM
nymike nymike is offline
2000 Chevy Silverado 4x4 tranny issue
I have a 2000 Chevy Silverado, 5.3L, 4L60 Tranny.
Original Transmission would not shift out of 1st or 2nd gear in higher gears. Bought and installed a rebuilt transmission and have the same problem.
What gives?
Local Chevy garage tells me it needs to be programmed! If that is the case why did the original tranny do the same thing. Can someone give me directions on where to start to fix this problem. All help appreciated...
Old 03-05-2010, 06:37 PM
j cAT j cAT is offline
Re: 2000 Chevy Silverado 4x4 tranny issue
What gives?
the fuses would be a start ..then pulling the oem drive train specific codes with the capable scanner is what most do ...If this is a chevrolet garage why are you asking these questions here...?
did you , or this chevrolet repair shop troubleshoot this ?
Old 03-05-2010, 07:11 PM
2000CAYukon 2000CAYukon is offline
Programming would only be necessary if you were changing something (shift points, firmness, etc). For a swap, programming is not required.
Listen to j Cat and find out if there are codes stored.
//2000CAYukon
Old 03-05-2010, 09:31 PM
kahjdh's Avatar
kahjdh kahjdh is offline
Limp mode will leave you stuck in 2nd, You need to know the codes before you can fix anything.
ASE Master Certified before the age of 20
Current Cars:
2001 Chevy Silverado 1500 Z71 5.3L
1996 Acura Integra LS B18 1.8L
Past Cars:
1990 Buick Estate Wagon 5.0L
1987 Chevy S10 2.5L Tec Four
1995 Pontiac Grand Am 2.3 Quad 4
1996 Jeep Grand Cherokee Limited 5.2L AWD
1991 Ford Tempo L 2.3L
1992 Buick LeSabre 3.8L
1997 Buick Century 3.1L
1996 Lumina APV GT 3.4L
2006 Ford Escape 3.0L XLT
Tags
4l60 , shifting , silverado , transmission
