Old 03-16-2004, 09:42 PM
4G4D Store's Avatar
4G4D Store 4G4D Store is offline
Send a message via ICQ to 4G4D Store Send a message via AIM to 4G4D Store Send a message via MSN to 4G4D Store Send a message via Yahoo to 4G4D Store
Timing Belt Broke today - are my valves shot??
So ya, I broke my timing belt. I didn't realize it until later, I thought it was my dizzy cause I wasn't getting spark. Then I realized that I wasn't getting any compression and the engine was turning over way to easy, sooooo - I pulled the valve cover and checked the timing belt - it wasn't even touching the cam gear. Any ideas?? Am I going to have to swap out the head, or the whole engine or just the timing belt or what??? Please help ASAP.
1991 Sedan LX Auto (Auto2Manual / MPFI / OBD1 conversions complete)
www.naytontech.com :: youtube.com/naytontech
Old 03-16-2004, 10:13 PM
slowCRXinPitt's Avatar
slowCRXinPitt slowCRXinPitt is offline
Wow, happened to me too last year. My gf was driving 50 on the highway when it broke . To my amazement the head/valves were fine. My mechanic said that hondas arent that bad when it comes to belts breaking. So you might be lucky... I'd say have the valves checked and be sure to be on top of things the next time
Old 03-16-2004, 10:17 PM
4G4D Store's Avatar
Do you know if there is anyway to tell if your valves are damaged without pulling the head off??
Old 03-16-2004, 10:19 PM
Re: Timing Belt Broke today - are my valves shot??
You have to take the head off bro..
Old 03-17-2004, 03:06 AM
slave slave is offline
BANNED
Or you can whack on a new timing belt, start it, if it does more damage, they're shagged.
Get it looked at. head off.
JDM IS NOT LHD
My other car's a Porsche, but today I'm in a hurry.
Old 03-17-2004, 03:28 AM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
i broke a belt on my old hatch. all i did to check it was spin the cam gear, everything spun freely, then spun the crank, again, no problem, and finally, put a timing belt on it and did a compression test. compression was fine. so i cranked it up, and it went another 30k before i swapped the engine out for a b16a
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 03-17-2004, 05:24 PM
4-Door Flunky 4-Door Flunky is offline
AF Premium User
The only way to know is to put a new timing belt on there and see if it runs. You could check the compression after you get the new belt on to be sure.
Mine broke while I was hauling ass down the highway. I didn't keep cranking on it when it wouldn't start, just got to work. My valves were fine. All is not lost!
Flunky
Old 03-17-2004, 06:10 PM
whobeyoube's Avatar
whobeyoube whobeyoube is offline
Send a message via AIM to whobeyoube Send a message via Yahoo to whobeyoube
yeah i agree as long as its not a dual b series you'll probably have good luck with it, set the timing and give it a shot.
Old 03-17-2004, 08:00 PM
crx91's Avatar
crx91 crx91 is offline
what whobeyoube said.set ur timing and crank it over.mine broke a couple of months ago,nothing happen to my valves.
Old 03-17-2004, 08:26 PM
4G4D Store's Avatar
Update - put new belt on, set timing and distributer, it'll start up, but won't rev past 3k. I'm thinking I've got a bad valve or two - also, I've used a timing light on it and the timing is dead on, so everthing should be working properly. I'm getting ready to pull the head off tomorrow.
Old 03-17-2004, 08:33 PM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
Before you pull the head make sure your timing is dead on. GL
Old 03-18-2004, 08:54 AM
rosshatch89 rosshatch89 is offline
Send a message via AIM to rosshatch89
do a compression test with your timing set right you should have around 100 psi same thing went to pass someone was at 6k when it snapped and i came out fine.
Old 03-18-2004, 10:32 AM
Mtrujillo's Avatar
Mtrujillo Mtrujillo is offline
Send a message via AIM to Mtrujillo Send a message via MSN to Mtrujillo
I hate doing timming belts they are such a pain in the ass! I wish they were chained timming belts instead...
Old 03-18-2004, 05:15 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
You could do a compression test and if it has 0 compression than you probably have a bent valve that isn't sealing. That is probably the easiest way.
Old 03-19-2004, 11:46 AM
4G4D Store's Avatar
Update - timing is dead on - the car would start and idle fine and rev up to 3k, but won't rev any higher. Pulled head off yesterday, valves are fine - put new gasket on and reassembled - retimed engine - exact same thing - I'm thinking distributor now - it's giving erros 4, 8, and 9. When I first broke the timing belt I tested the spark and got none (obviously, cam wasn't moving) so I replaced my distro under warranty. Now I'm suspecting that the one they gave me is DOA and has a bad TDC and crank angle sensor in it. This totally sucks because they have my good one now and I have a bad one, my car would be running right now. There aren't any in my area so they have ordered a new one and it should be tomorrow. I hope so then I can put my car back together and drive it again.
How to change timing belt? RainSpirit44 SVX 2 03-25-2009 04:30 AM
Timing belt broke :( BigBearWest '88 - '91 Civic | CRX | Wagon | Shuttlee 28 06-23-2004 04:17 PM
Timing Belt broke....now won't start tomtsc Escort 3 05-26-2004 05:40 PM
92 escort wgn/timing belt broke 1.9L auto daveysaun Escort 4 04-07-2004 06:29 PM
Timing Belt broke today.....help!!! krazylowgsx Grand Prix 5 03-18-2004 10:01 AM
