Old 05-10-2004, 11:53 PM
BigBearWest's Avatar
BigBearWest BigBearWest is offline
WWW.CalgarysFinest.COM
Send a message via ICQ to BigBearWest Send a message via AIM to BigBearWest Send a message via MSN to BigBearWest
Timing belt broke :(
so my belt broke today. is there any tips on changing it? I have changed a mazda 626 and a dogde colt timing belts before is it simaliar
My Name is Roberto AKA. Berto
Old 05-11-2004, 12:12 AM
91hbman 91hbman is offline
Send a message via Yahoo to 91hbman
Re: Timing belt broke :(
well make sure none of the valves are bent, if they are you'll want to replace them.
Thanks for any of the help that anybody has offered. I try to do the same. And remember "It takes all kinds to make the world go round."
Old 05-11-2004, 12:16 AM
oldschoolcivic's Avatar
oldschoolcivic oldschoolcivic is offline
I would take off the head. when your belt broke the belt it probable bent some valves. replacing the belt is just taking off the cover, loosen the tensioner, and making sure the cam is alligned with the crank then put on the belt. I would recomend a manual, it really helps. Besides it only like $17.
Old 05-11-2004, 12:48 AM
do i have to remove the engine mount?
Old 05-11-2004, 02:55 AM
Re: Re: Timing belt broke :(
Yeah just put a jack under the motor to support it while you take off the mount.
Old 05-11-2004, 12:45 PM
Re: Re: Re: Timing belt broke :(
ok thanks
Old 05-11-2004, 01:46 PM
slowCRXinPitt's Avatar
slowCRXinPitt slowCRXinPitt is offline
Ill bet $ that you didnt bend any valves. I know of at least a dozen honda owners who have broken their timing belts, myself included, who have not bent any valves. I'll keep my fingers crossed for you.
Old 05-11-2004, 05:50 PM
kicker1_solo's Avatar
kicker1_solo kicker1_solo is offline
Send a message via AIM to kicker1_solo Send a message via Yahoo to kicker1_solo
agreed, happened to me a few weeks ago and things are fine.
2000 BMW 323IT
1954 Ford F100
With every post my penis grows smaller
Yakima Valley Truck Club Yakima Washington
Old 05-11-2004, 07:57 PM
90civicracer's Avatar
90civicracer 90civicracer is offline
Send a message via AIM to 90civicracer
It doesnt mean you bent your valves, but a lot of times it does bend some valves. It'd be smart to check while your car is out.
***90 Civic EX 4 Door***
Ace$nyper: yea it did woo woo 4500 posts i should be ashamed *kills self*
90civicracer: haha you killed yourself you got
Ace$nyper: OMFG LOL that might be the funniest thing you EVER posted
bwhahahaha
Old 05-12-2004, 04:09 AM
compakt compakt is offline
check your compression as well just incase.
Old 05-12-2004, 10:52 AM
4-Door Flunky 4-Door Flunky is offline
AF Premium User
I recommend putting on the new timing belt, then doing a compression test.
My belt gave up the ghost while I was zooming down the freeway, but none of my valves were injured.
I hope you were lucky like that, too.
Flunky
Old 05-12-2004, 11:08 AM
travagliante's Avatar
travagliante travagliante is offline
hmmm if your timing belt broke of course you would have tio replace it. lol
Old 05-12-2004, 01:45 PM
Well it turns out that i didn't bend any valves and i found out where my oil leak was from, it was my crankshaft seal
Old 05-12-2004, 06:31 PM
good, very good. glad that you found the problem... Wish it was that easy for me...
Old 06-09-2004, 03:28 AM
kayuman kayuman is offline
Mine broke four days ago! I got it towed to the shop, as I am no mechanic!
The mechanic told me that there were some valves that were bent.
The valves needed to be replaced and the heads neede to be machined. I said OK and to replace the water pump too. When I got my car back, it lacks power! When I press down on the gas the car hesistates and then pickups real slow. Then when I am driving, it losses power when I am going on an incline and then force to down shift. Could this be a timing issue? Can anyone help.
I have searched the net for help, but found no resolution, but found a real kwel site: http://crxsi.com/resources/repair/ch...belt/index.htm
were it shows a step by step how to change the timing belt / water pump.
I am taking my car back on friday! But, would like to know what is causing this problem. After all I got warranty on the repair that cost me $1,500.00.
Any help appreciated!
-kayuman
