Old 03-15-2004, 07:11 PM
Igovert500's Avatar
blue + red light magnet
battery
Ok, while waiting for the money for new tires and a rim, the cold NY weather and my python alarm killed my stock battery. So now I need to replace it. My question is: What to get?
I have the front tower strut bar that interferes with the stock battery as it is. That was a b!tch just to install, and took alot of "finnessing".
Also, I have a 12 disc cd changer, equalizer, and amp in the car, a python alarm, and the cold weather. So it needs lots of cranking amps.
Optima redtops??? Any thoughts. I don't really want to relocate it to the trunk, but perhaps in the future, but for now i just want something that will work reliably and fit with the strut bar. What is the popular choice..? Any advice/experiences are greatly appreciated.
Old 03-16-2004, 12:55 PM
YogsVR4's Avatar
YogsVR4 YogsVR4 is offline
Funding the welfare state
Send a message via AIM to YogsVR4
I've used the Diehards from Sears and they've done a great job for me. I don't have need for the extra juice like you do, but its never failed to crank over the car regardless of the temperature.
Resistance Is Futile (If < 1ohm)
Old 03-16-2004, 01:08 PM
Igovert500's Avatar
Re: battery
how much do those cost roughly? I think the optimas are in the range of 130 if I'm not mistaken.
Old 03-16-2004, 03:36 PM
YogsVR4's Avatar
http://www.sears.com/sr/javasr/produ...id=02833025000 Comes back at about $80
Old 03-16-2004, 05:19 PM
Teazrsnow Teazrsnow is offline
Send a message via AIM to Teazrsnow Send a message via Yahoo to Teazrsnow
Re: battery
optimas are great for basically everything, but one thing you should also think about getting is a capacitor for your amp(unless its low powered)
Tyler Laabs
2nd Place Drag racing Fwd 3s National Gathering 03[
Old 03-16-2004, 08:32 PM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Re: battery
Dude, I sell alarms and I'll tell you there is NO way an alarm killed your battery. The nominal drain is less than what it takes your radio to hold it's presets even when armed. The only way it could kill the battery is if the parking light relay stuck or something like that. Everything else on that alarm is (-) triggered.
Old 03-17-2004, 01:26 PM
Igovert500's Avatar
Re: battery
No, I didn't mean that the alarm killed it. I live in the freezing hell known as central NY. I had 2 flats and over the month that my car was sitting outside in sub 0 temperatures without moving it died. I didn't mean to imply that the alarm was the main cause, I am just saying that all the electronics probably didn't help (don't know to much about batteries, I just figured).
2001 Cavalier Battery Drain Problem - HELP amberdamber7 Cavalier Problem Diagnosis 25 03-25-2009 06:30 PM
Battery light on and just put in a new battery. Help! 1996SC1 SC/SL/SW 4 04-17-2005 12:56 AM
HELP! Battery Light on - Battery is good mariedylanj Grand AM 5 08-28-2004 08:05 AM
replaced alternator & battery/battery still dying krazidame7 Engineering/ Technical 3 03-06-2004 05:17 AM
Battery or Alternator? Won't charge the battery... xs29l Intrepid 1 02-09-2004 11:30 PM
