Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 08-12-2004, 01:01 PM
1996SC1 1996SC1 is offline
Battery light on and just put in a new battery. Help!
1996 SC1 - Just put in a brand new battery two days ago. Battery light just came on last night. Could this mean the new battery is not good or is there some other potential electrical issue? The battery light did not come on for two days and the car was driven numerous times. This forum has been a great help for issues. Thanks.
Old 08-12-2004, 11:32 PM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
Re: Battery light on and just put in a new battery. Help!
why was the battery replaced?
the battery should be rated at 550 cold cranking amps or higher.
double check that the bolts are tight. careful when checking the positive side, don't let anything medal(namey a wrench) touch the positive bolt to anything else on the car. bad things will happen.
also possibly a bad alternator. the right way to test it is take to a shop or take it off yourself and have a part store test it(most will for free).
heres the redneck way to test it - let the can run in park, headlights, radio, A/C, everything turned on.if it dies by itself, its the alternater.(it will take a little time, but i doubt more then 30 minutes)if this is the case, you will need to recharge or jump the battery.
Old 10-08-2004, 11:01 AM
dw97sc1 dw97sc1 is offline
Send a message via AIM to dw97sc1 Send a message via MSN to dw97sc1
Or check the fuseable link between the starter and the alternator. Could be a broken wire, it happened to me. Just be VERY careful with the stud on the alternator. Use two wrenches to hold the inside nut still when taking the outside nut off of the stud. If the stud twists bye bye alternator.
Old 12-05-2004, 05:37 PM
97BlazerLT's Avatar
97BlazerLT 97BlazerLT is offline
Send a message via MSN to 97BlazerLT Send a message via Yahoo to 97BlazerLT
Re: Re: Battery light on and just put in a new battery. Help!
Check the alternator!!!
Old 04-17-2005, 12:56 AM
96saturn 96saturn is offline
its most likely your alternator, mine went two days after the light came on so do it soon.
