Old 03-11-2004, 09:30 PM
Bmaintz Bmaintz is offline
88 Cherokee Gas Guage not working???
New to the Forum & need your HELP....
I pulled the instrument cluster & checked the ohms on harness back to gas tank sender, I had 45 ohms, put 5 gals in it & had 60 ohms... The ohms will go up & down as you move the Jeep around.... I am assuming that the Sender Unit is OK.... Have cleaned all contact on cluster, even removed the gas guage & cleaned its contacts... The cluster is getting a good ground... The dash lights work OK.... Does the large Gas Guages go bad, the needle seemed stiff to move....
Many Thanks,
Bob
Old 04-07-2004, 08:17 PM
[XR]STUD [XR]STUD is offline
gas gauge not working?
usually a gas gauge works or it doesn't...no in between....remove the wire from the sending unit at the tank...with the key on, have someone watch the gauge while you touch the wire to a good ground, like the body or frame...the gauge should go right up to full or past full...it only takes a couple seconds...if it does this, everything is working back to the tank...check for bad ground connections at the sending unit in the top of the tank....remember, the gauge has low voltage through it anytime the key is on....the change in gauge indication is through variable resistance to ground at the tank....make sure you dont use the fuel pump power wire for this test...pump wire will have around 12 volts or more....gauge wire will have around 5 volts....good luck!
Old 04-07-2004, 08:34 PM
Re: 88 Cherokee Gas Guage not working???
Thanks,
Turns out that the Cherokee had a salvage title so we made the auction take it back plus $400 for my trouble... Bob
'01 Intrigue: Gas Guage Not Working.... vanhalen1979 Intrigue 9 11-21-2008 03:07 AM
gas guage not working on 93 grand cherokee bigd7315 Cherokee 0 10-01-2008 10:59 PM
gas guage not working..? t3dizzle Non-Performance 1 04-02-2008 07:38 PM
3 questions, electric fan constantly running, gas guage not working, and guages... cardboardpimp420 F-Body Problem Diagnosis 3 06-27-2007 11:18 AM
Gas Guage Not Working uamrhti S-10 3 11-15-2005 09:41 PM
