Old 03-09-2004, 11:55 AM
Frank D Frank D is offline
2002 Windstar fuel filter location
Hi everyone. Doing some 30,000 mile maintenence on my Windstar and need some help locating the fuel filter so I can replace it. Thanks.
Old 03-09-2004, 05:44 PM
lewisnc100 lewisnc100 is offline
Should be the same as my 2000, on the driver's side right where the front and rear door pillars meet, just look underneath on the inside of the frame and you should see it.
Old 03-10-2004, 04:25 PM
Re: 2002 Windstar fuel filter location
Thanks for the reply. Just came back in from looking under the car where you said but I could not find it there. Is it enclosed in a black plastic case that is there?
Old 03-10-2004, 08:23 PM
Re: Re: 2002 Windstar fuel filter location
No, pretty obvious but it was in far enough that you need to jack the van up to be able to see it unless they moved it since my 2000.
Old 03-11-2004, 05:16 AM
rodeo02 rodeo02 is offline
On my 2001, it's mounted right inside the frame rail where Lewis pointed out. It's a typical cannister style filter, a little smaller than a soup can.
G/luck
Joel
Old 04-05-2004, 10:01 PM
SRamsey625 SRamsey625 is offline
G/luck
Joel
That's where mine is on my 99 also. Don't forget to bleed the pressure off your fuel system if you've driven it. There's a "valve stem" on the fuel rail front side of engine driver side or just let it sit overnight and do it first thing before you start it. Pressure should bleed off overnight. That's the best way. Or else you will be taking a shower in gas.
Old 04-06-2004, 07:27 AM
I pull the fuel pump relay and give it a few cranks, that will clear any pressure in the system.
Old 04-30-2004, 02:37 PM
Skip202003's Avatar
Skip202003 Skip202003 is offline
Hi . I'm new to this forum stuff, hope I'm doing it right. Whehe is the fuel pump relay located on a 1999 ford winstar?
Old 05-01-2004, 08:59 AM
Take a look in your owner's manual, it shows the location of the box and the individual relay. Should be in your engine compartment all the way on the driver's side. Once you get it open check the diagram in your owner's manual to determine the correct relay to pull.
Old 07-04-2004, 06:49 PM
Sorry for not answering sooner but I found it right where all said it would be when I put it on the ramps and it was very easy to replace and no gas shower either, Thanks again.
Fuel Filter Location - 2002 Sport Trac bfbfbf Explorer | Explorer Sport Trac 3 09-15-2008 07:03 AM
? Can't locate fuel filter location nmcarguy Rio | Rio Cinco | Pride 2 01-31-2007 07:53 AM
2002 Sienna - Fuel Filter Location GTS767 Sienna 1 11-04-2006 07:24 PM
sonata 2002 fuel filter location soh Sonata 0 05-03-2006 02:59 AM
99 windstar oil filter location mden6 Windstar 3 04-03-2006 11:20 AM
